What the hell could be going on with this thing?
It started on 01/02/2023 just fine. Today i went out about the same time of day and it would not start even after several attempts.
It did basically what it did before, almost starts, but then doesnt actually start. Sounds like it will start, then does not. So it fires ok for a few revolutions, then shuts down.
1998v70 Car Will Not Start AGAIN
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- Been thanked: 4064 times
You need to split your path of diagnostic tree into either ignition or fuel issue.
The simplest way to do this is with starter fluid , a 3 second shot into the throttle body. If it Vrooooms suddenly? It’s a fuel issue.
If not, an ignition issue
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
For the ignition, turn the key to start and if it does not and stops leave it in the II position. Take a long jumper wire and touch the battery and the positive post on the starter and see if will continue to crank and start.
Oldmanrocker98S70
- Year and Model: 1998 S70
I have had same problem with my 98 S70 cranks, fires, and dies .I have heard it could be a Coolant Temp Sensor issue in cold weather >it starts fine in higher temps
The Kat is doing this to me right now. 1999 s70
You can check the ECT against the resistance chart to see if it matches. It has to be really close. Those charts are in this forum
Use a Volvo part here. No aftermarket.
For you -1998 plonkers here is some UK data
viewtopic.php?t=96534
- MrAl
Hi,abscate wrote: 06 Jan 2023, 13:52 You need to split your path of diagnostic tree into either ignition or fuel issue.
Where is the throttle body on this car everything looks sealed.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
There's also a vacuum tree on the intake you could shoot some in, without having to mess with opening the throttle.
I'm also going to suggest (re)checking the ECT sensor and connector. I had a bad one that really gave me fits when it was cold. It ran marginally bad when it was cool, but when it got cold, it wouldn't start, and was unhappy with any attempts to make it start.
- MrAl
Yes thanks, but it's all sealed up. I'd have to remove that big accordion tube.crlande wrote: 07 Jan 2023, 06:32 Air filter box, follow the accordion looking tube from there, it ends at the throttle body.
- MrAl
Ok i guess that ECT will have to be checked again at some point. Just had it replaced about a year ago.Chuck W wrote: 07 Jan 2023, 06:40 There's also a vacuum tree on the intake you could shoot some in, without having to mess with opening the throttle.
You mean shoot some in where the air filter is?
- 118 Replies
- 8818 Views
Last post by BlackBart
- 1351 Views
- 13 Replies
- 12212 Views
Last post by SVO LOU
- 37 Replies
- 8501 Views
Last post by songzunhuang
- 797 Views
Last post by T64me
