Do I need a breaker bar.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Re: Do I need a breaker bar.
Didn't hear anything with my bolts. But I was using torque assembly lubricant on the head bolts.
- Has thanked: 927 times
- Been thanked: 1000 times
My opinion is the noises when turning is from the friction in the joint. Thread lube will reduce the friction between the bolt head and cylinder head and the bolt and block threads. This is good. The friction interferes with the proper torque.
You could have used an extension pipe on the last tightening, since it angle of rotation instead of torque measurement. It would ease the load on your muscles and joints.
Well done. You should feel satisfaction.
- 829 Views
Last post by darrylrobert
- 9619 Views
Last post by SuperHerman
