I realize I’ve never used winter blades even in Buffalo and deep cold Ithaca.
Starting car, clearing off snow, and then clearing windshield is the key. Never wipe a heavy snow laden windshield with your wipers. Bad for everything ,,, blades, gears, arms, and wiper motor.
Ok, Snow folks, what's your prefered winter wiper blade?
- Been thanked: 4064 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
You've never gotten salt spray from someone in front of you, or it's snowing hard enough to accumulate while driving?abscate wrote: 05 Feb 2022, 02:58 I realize I’ve never used winter blades even in Buffalo and deep cold Ithaca.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
If it starts building up, stop and clear it off. That’s also Nature telling you you to get off the roads, too. If you are having trouble seeing, everyone else is too, and that doesn’t end well.
454cid
I bought Trico's Ultra blades. They're US made, unlike most. Since they're a beam style, they should work in the winter. Unfortunately, they must be lower profile than what was there, since the driver's side doesn't completely clear the window. The last few inches of the arc, the center of the blade lifts off the glass and there is no snow/ice as it was 40F today.
I also noticed that since they're a bit bulkier than the conventional blades that were there, that the passenger side is a little bit up on the windshield when off/parked, but only sometimes. Does the wiper system use some sort of control board? On my Chevy truck the wipers have a control board that often has bad solder joints, much like the Volvo abs module, and will act up.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
There's a timer control, but the motor and linkage are old school.
Home position is returned to when a position switch in the motor
opens after switched operating power is removed from the motor.
If you're seeing inconsistency in home positions between the two
arms, I'd start with the arm connection at the wiper shaft. May be loose.
454cid
Thank you, I'll look at that. Maybe this weekend.BEJinFbk wrote: 10 Feb 2022, 00:27 There's a timer control, but the motor and linkage are old school.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 15 Replies
- 2064 Views
- 1573 Views
Last post by skloon
- 3366 Views
Last post by Durenol
- 2875 Views
Last post by Rattnalle
- 12 Replies
- 4674 Views
Last post by motormikeyman
