It has a metric thread. I know I have used an oil drain plug before but do not recall if it was a P80 one or I bought one at the parts store.454cid wrote: 10 Apr 2022, 23:51Yes, I'm considering both options. I'll have more time to dink around with it in a week.erikv11 wrote: 10 Apr 2022, 13:59 SAS makes some sense too. Maybe time to get rid of it? Or at least block it off to troubleshoot.
Any idea what the thread on the header/manifold is, where the pipe screws in? I've read "pipe plug" a few times, but I have my doubts about it being NPT.
Running VERY rich and IAT
- Has thanked: 311 times
- Been thanked: 817 times
I’ve got loose headers and can measure these threads when I’m back at my cars next week
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
When I first start the car up, it's always sounded a bit rougher than I'd expect, but I've always assumed it was because I'm not used to listening to a 5 cylinder, or the fact that it uses a steel header rather than a cast ironSirBrickWagon wrote: 11 Apr 2022, 10:34
a common place on naturally aspirated volvos tends to be near the flex joint connecting the manifold to the exhaust pipe. that was my issue, but it sounded rough and loud.
manifold.
What was the fix for your car, a new manifold/header?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Did you seal the threads with something? An oil drain plug would be a straight thread, that would not be conducive to sealing by itself.erikv11 wrote: 11 Apr 2022, 13:19
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
That would be fantastic.abscate wrote: 11 Apr 2022, 13:43 I’ve got loose headers and can measure these threads when I’m back at my cars next week
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
SirBrickWagon
- Year and Model: 1997 Volvo 850
- Has thanked: 7 times
- Been thanked: 11 times
unfortunately it's around 150 dollars ish, but yes. that was the fix. only difference is that mine was entirely blown out, some exhaust tape might be a better fix for you as of right now, but definitely new headers at some point. before going ahead and buying headers though, pop your hood, start the car, and listen around in the engine bay. this can be made easier with a long tube you can put near the flex joint and listen on the other end, to know for sure. or, if you're willing to trade risk for ease of access, just hovering your hand around the flex joint is always a feasible option to feel for any leaks hitting your hand.454cid wrote: 12 Apr 2022, 01:35When I first start the car up, it's always sounded a bit rougher than I'd expect, but I've always assumed it was because I'm not used to listening to a 5 cylinder, or the fact that it uses a steel header rather than a cast ironSirBrickWagon wrote: 11 Apr 2022, 10:34
manifold.
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
Yep I glued it in with some kind of tailpipe sealant paste.454cid wrote: 12 Apr 2022, 01:37Did you seal the threads with something? An oil drain plug would be a straight thread, that would not be conducive to sealing by itself.erikv11 wrote: 11 Apr 2022, 13:19
- 1900 Views
Last post by 93Regina
- 1918 Views
Last post by warmblood58
- 19 Replies
- 5623 Views
Last post by Sommerfeldt
- 14 Replies
- 3137 Views
Last post by Kuhnboy
- 441 Views
Last post by classical
