It is in the same carconfigoscilloscope wrote: 12 Jun 2022, 02:37
sorry to jump in what your talking about , is the "carconfig" option with the CEM hack ware on git. or is this a separate piece of software that is avalible ?
Vida CEM swapping
ZRimaZ
- Year and Model: XC60 MY2016 3.0 T6
- Has thanked: 23 times
- Been thanked: 13 times
Have a nice day,
ZRimaZ
ZRimaZ
- RickHaleParker
- Been thanked: 979 times
Where is the PIN in the 68376 flash ?
Active
Past
Past
matija0610
- Year and Model: 2003 S60 D5
- Has thanked: 21 times
@6000 or @4000
- RickHaleParker
Is there a shuffle order ?
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
No, but endianness is different (do bswap_16).
Wrote this to aid the brick CEM cracking.
Code: Select all
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <assert.h>
int main(int argc, char *argv[])
int ifd = open(argv[1], O_RDONLY);
int ofd = open(argv[2], O_RDWR | O_CREAT, 0666);
int i, ret;
unsigned char buf[256];
assert(ifd > 0);
assert(ofd > 0);
do {
ret = read(ifd, buf, sizeof(buf));
if (ret <= 0)
break;
for (i = 0; i < sizeof(buf); i += 2) {
unsigned char tmp = buf[i];
buf[i] = buf[i + 1];
buf[i + 1] = tmp;
write(ofd, buf, sizeof(buf));
} while (ret > 0);
close(ifd);
close(ofd);
return 0;
vtl
I'm lazy and have no free time this summer to pull off the CEM for reflashing (and cars - we've sold wife's Ford XC60, but couldn't get a replacement, so both car and truck should be on wheels at all times). Need something over OBD. Maybe I'll just pull the siren and leave the flash-over-CAN project till later.ZRimaZ wrote: 12 Jun 2022, 01:12 You have to remove alarm in cem config and after - disconnect siren. If you have cem flash, send it to me, i'll remove alarm from config ( in case if you do not know, how to do it)
vtl
Oh, also, also... Maybe internet wisdom knows at least where to start looking at... I'm planning upgrading my tires (and suspension) from stock 27" to 29", but want to keep the speedometer/odometer sane. I know there's a tire size selection somewhere in car (CEM? TCM?). Unfortunately, 215/65R16 is the biggest size. I need to tweak that as well. So the question is: what ECU keeps the tire size?ZRimaZ wrote: 12 Jun 2022, 01:12 You have to remove alarm in cem config and after - disconnect siren. If you have cem flash, send it to me, i'll remove alarm from config ( in case if you do not know, how to do it)
ZRimaZ
Yes, there're one or two parameters in config, depending on MY. But is is very strange with it, I have to clear it myself - on Friday I made ECM, TCM and DEM software upgrade online for my XC60 MY2016. Originally it is from USA, but already converted to EU and, of course, after upgrade everything came back to original configuration - USA, so I had to make US-EU conversion again. At the same time I decided to do the samo operation as you - adjust tyre size and tyre circumference to the real one - 235/60/R18 and 2322mm instead of programmed from factory, which is 215/55 R16 W and 2250.vtl wrote: 12 Jun 2022, 08:33
Done. Config appeared OK, but DIM DTC about wrong configuration came up. Did not pay attention, because was not sute ig it was not before...
Returning from work to home just got message that traction control is off and blinking tyre pressure indicator. OK, probably puncture
So, the answer to your question - yes, there are tyre size parameters, but....
OMG! Long-story-teller!!!
Have a nice day,
ZRimaZ
ZRimaZ
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
235/60R18:ZRimaZ wrote: 12 Jun 2022, 09:53 I decided to adjust tyre size and tyre circumference to the real one - 235/60/R18 and 2322mm instead of programmed from factory, which is 215/55 R16 W and 2250.
Done.
π*((235*0.60*2)+(18*25.4))=2322.27mm
215/55R16:
π*((215*0.55*2)+(16*25.4))=2019.73mm
Not sure where 2250mm came from...
ZRimaZ
Me too. But it is from factorygnalan wrote: 12 Jun 2022, 10:22
235/60R18:
215/55R16
Have a nice day,
ZRimaZ
ZRimaZ
- 9188 Views
Last post by RickHaleParker
- 9098 Views
- 27 Replies
- 28252 Views
Last post by cn90
- 10552 Views
Last post by jonesg
- 5706 Views
