jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
BlackBart wrote: 23 Jul 2022, 09:17 Just a question -
Does anyone go to a quality independent shop where the guy can cleverly copy the OE system? Or is he just ordering bargain aftermarket pieces to build it up?
quality is laughable up here, clown show is the normal.
the local place took 5 months to replace my radiator, from january to june.
Should never have said 'no rush'.
on top of that they asked if i wanted to prepay, I said 'you haven't done anything yet' .
When I had my tires balanced they did a courtesy check, the car went in there with a slight phhffft leak at the flange, came out blasting exhaust, they obviously yanked it loose.
I watched a roofing company take 5 weeks to do a roof that i know would be done in one day in boston, my buddy was a roofer.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
jonesg wrote: 23 Jul 2022, 13:46 I watched a roofing company take 5 weeks to do a roof that i know would be done in one day in boston, my buddy was a roofer.
Hold on, hold on... Boston Logan is 40 minutes away.
Wife's pissed off at me (working slowly in my second shift, at her house project that's undergoing a huge renovation), so she hired top guys with "Elite" in their gang name. Not cheap! Quite the opposite! The first thing they did is 6 wooden vents, $70 each, installed up side down. Every one was wrapped in a box with huge red warning saying in clear English to flip it backwards before installation.
That was when, like two months ago? They haven't finished yet. I'm about to finish whatever I'm doing wife-unacceptably slowly, take their job and command to GTFO.
Where are you 100 miles from Bangor? I'm driving up north a few times a year, to went out in woods around Millinocket/Ashland, may have a drink with a Volvo fellow :)
jonesg
Post by jonesg »
come on up, we're 45 minutes north of millinocket in Island Falls.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
100°F today but the 08 needed an oil change. Wasn't awful with a fan directly on me in the garage. Also drained and filled the transmission, third time in last three oil changes so should now be good and shifts really smooth.
The oil filter looked really really good given this 3000 mile change had a half quart of MMO in it to help with any potential sludge. This being the third change ready for 5000 mile intervals now. Bought with 138k and now at 144k, it's a keeper.
08 C702.5T (sold)
The non-Swedes:
jonesg
Post by jonesg »
Krons wrote: 23 Jul 2022, 18:04 100°F today but the 08 needed an oil change. Wasn't awful with a fan directly on me in the garage. Also drained and filled the transmission, third time in last three oil changes so should now be good and shifts really smooth.
'in the garage' is what makes it doable, I have a small aircon running in mine, keeps it tolerable but not really chill.
Without the garage I'd have to start at 5 am to beat the sun.
jonesg
Post by jonesg »
anyone know if the sway bar bushings can be changed without dropping the sub frame ?
04 V70 turbo awd.
vtl
Post by vtl »
jonesg wrote: 23 Jul 2022, 18:48 anyone know if the sway bar bushings can be changed without dropping the sub frame ?
04 V70 turbo awd.
No. Need to slacken the front bolts and lower the subframe 2-3" in back. Don't forget to disconnect the steering rack from the steering shaft.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Has anyone heard from oragex in a while? I remember something about him having health issues. Hope he's okay. He's definitely contributed a lot here. His videos had sometimes led me down the garden path, but overall they've been a huge help and very unique in their information provided.
04s60 2.4
04xc70 2.5t
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Today I steam cleaned the carpets, under the rear seat, and the way back carpet. Ace hardware rents them with a hand sprayer attachment.
Has thanked: 1611 times
Been thanked: 4075 times
jonesg wrote: 16 Jul 2022, 13:32 so I finally sealed the leak at the cat to resonator flange. The flange bolt holes were rotted away.
, I put a split coupler on each side of the joint,
a 3 inch section of 63mm pipe inserted (hammered) in the cat side,
resonator side is slightly bigger , the flange bolts drew it together.
Firefox31 posted a link to a firm that makes a great flange joint you can clamp or weld on, for about $35
