- Has thanked: 317 times
- Been thanked: 531 times
Yeah, it looks to be much simpler than it is. That bottom bolt is a real pain. Luckily I was able to get at it with a single 12 inch extension on a 1/4" ratchet.
- Has thanked: 2215 times
- Been thanked: 1853 times
Hey LOB, I'm surprised the Haynes manual didn't say, you require to use a wrench, take it to your nearest dealer who pays us to give you crap advice so you have to take it the the dealer....!
850 alternator is a pain to do. Sympathies..
LOB
- Year and Model: 855 GLT 2.5T
- Has thanked: 10 times
- Been thanked: 16 times
Hi Scot 850!
Don't know if some information is lost in translation to Swedish but my Haynes manual doesn't go into detail. It just says " remove the 5 bolts of the..." Choosing a wrench for tool was however not rocket science. There are a few other manuals that might be better than Haynes. Though, the knowledge base in this forum outperform any manual!
- Has thanked: 1613 times
- Been thanked: 4078 times
Drive the 1999 700 miles round trip around New England, and the growling alternator now has marbles in it. Limped back in from ROC last night promising to put the spare in this weekend.
Rebuilt it 20k but my guess is the rebuilder greased old bearings instead of replacing. You're fired
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
The Haynes manual became utterly obsolete when this very forum was created! After I found Matthews I never opened mine again, because the hands on experience of many is so much more valuable than the writing of one.LOB wrote: 09 Nov 2017, 01:31 Hi Scot 850!
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 850 LPT
I'm in the process of replacing the radiator in the 98' XC and I'm running into a problem. Last night I got down to the last two bolts that hold the thing to the frame when one of those welded nuts came loose. Grrrrr!
I should have noticed before I started to loosen these bolts that they were badly corroded.
Now I soaked them with Pb blaster but maybe I'll try to cut the bolt off with a Dremel tonight, there doesn't seem to be enough space to get a vise grip on.
13' Honda Odyssey
13' Honda Odyssey
The radiator is a fun job too. My cousin and I actually knocked it out on his '99 in probably 45 minutes, and it was a pain because my hands were all hacked up from working on my Saab the rest of the week before, and he didn't have any gloves. Plus having to work around the PO's horrible garden hose tranny cooler line rebuild... I wish he would stop being lazy and just replace those lines already. One is leaking at the transmission and he'd rather glob some RTV on it to seal the leak.
I had to drill mine out on my 99 ,back in 2013850 LPT wrote: 09 Nov 2017, 06:55 I'm in the process of replacing the radiator in the 98' XC and I'm running into a problem. Last night I got down to the last two bolts that hold the thing to the frame when one of those welded nuts came loose. Grrrrr!
I replaced them with SS bolt and nut with washers - when I did the radiator again in 2017 they came right off.
- Martin_Frydenbo
- Year and Model: '94 850 2.5 10V
Changed my exhaust system on my 855 to a stainless steel and 2,5 inch from cat.
Made a very nice sound and actually gave it a bit more omphh in the higher revs.
Volvo Technician with access to VIDA
2014 Volvo V40 T3
2014 Volvo V70 T4
1994 Volvo 850 SE 2.5 10V NA
2014 Volvo V40 T3
2014 Volvo V70 T4
- 850 LPT
Very nice! Did you get a custom job done or use an aftermarket exhaust?Martin_Frydenbo wrote: 09 Nov 2017, 23:43 Changed my exhaust system on my 855 to a stainless steel and 2,5 inch from cat.
13' Honda Odyssey
13' Honda Odyssey
