Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Nice! ;)
Zener diode is for safety.
As said elsewhere, I was rebuilding my blown engine. It is up and running now, but I need to pass a long overdue yearly inspection, for which the car should have no codes erased for last 100 or 200 miles (erasing codes zeroes emissions readiness). I'll try it in car once I get a new sticker on the windshield.
efe09
Year and Model: 2009 XC90 D5
Has thanked: 17 times
Post by efe09 »
hi vtl,
hi all,
now I have to try it on my XC90
and hope that it works.
Are there any other disadvantages of resetting the CEM pin?
vtl
Post by vtl »
What do you mean by "resetting"? Setting it to 0?
efe09
Post by efe09 »
I actually meant disadvantages,of decoding with the CEM Cracker??
Please excuse my bad English.
vtl
Post by vtl »
Depends on who you are. For Volvo, VDASH and alike folks it's a loose-loose situation when prospective customer can figure the PIN out on his own ;) Otherwise I don't see any drawbacks of being able to keep your old good car on the road for a bit longer and for a bit cheaper.
efe09
Post by efe09 »
I have just ventured a test on the car.
As soon as I connect the OBD2 connector and after the message "sending CEM into programming Mode" I set the ignition to position 2, the serial monitor shows the following message
CPU Maximum Frequency: 600000000
CPU Frequency: 180000000
Execution Rate: 180 cycles/us
Minimum CEM Reply Time: 30us
Platform: P2
PIN bytes to measure: 3
Number of samples: 30
Number of loops: 1000
Initialization done.
sending CEM into programming mode
send: ID=000ffffe data=ff 86 00 00 00 00 00 00
calculating bytes 0-2
After that, the XC90 is dead.
Until I with VDASH all the ECUs in the car
reboot and brought back to life.
vtl
Post by vtl »
Is it everything it prints? You're missing CAN setup messages and CEM part number readout.
efe09
Post by efe09 »
i have only come so far today,
here in Germany it is cold.I will try again tomorrow
and can tell you more about it
efe09
Post by efe09 »
I will connect a charger to the car tomorrow; because the car battery is very quickly empty, as soon as OBD2 is connected.
I thought I could make it like you in YOUTUBE
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
efe09 wrote: 13 Jan 2021, 11:37 I will connect a charger to the car tomorrow; because the car battery is very quickly empty, as soon as OBD2 is connected.
The battery might may have a build up of Lead Sulfate Crystals ( sulfation ). Move the battery inside and let it float charge for a couple of days, weeks, months. The float charging will convert the Lead Sulfate Crystals back into lead and you will regain capacity. How long it take depends on how bad it is. If your battery charger has a pulse mode the pulses will speed up desulfation.
Tip: When the battery charger says fully charged. Disconnect charger for 20 minutes then reconnect charger. Keep doing this until it only takes a few minutes to go from reconnect to full charge. Thereafter keep the battery on float charge to maintain it by keeping it from sulfating again
Active
Past
