gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
abscate wrote: 24 Jul 2022, 02:21 Firefox31 posted a link to a firm that makes a great flange joint you can clamp or weld on, for about $35
viewtopic.php?p=605573&hilit=flange#p605573
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
jonesg wrote: 16 Jul 2022, 13:32 so I finally sealed the leak at the cat to resonator flange. The flange bolt holes were rotted away.
, I put a split coupler on each side of the joint,
a 3 inch section of 63mm pipe inserted (hammered) in the cat side,
resonator side is slightly bigger , the flange bolts drew it together.
I just ordered this one last night,
https://www.amazon.com/gp/product/B087J ... UTF8&psc=1
jonesg
Post by jonesg »
clicking knock sound from passenger front side, rocking the car side to side its loud ,
so I put the car on the ramps and of course it goes away.
I call that a win.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
jonesg wrote: 28 Jul 2022, 00:37 clicking knock sound from passenger front side, rocking the car side to side its loud ,
I call that a win.
End link, perhaps?
jonesg
Post by jonesg »
vtl wrote: 28 Jul 2022, 06:25
I call that a win.
End link, perhaps?
I did both sides 3 weeks ago, I'd better check them again.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
My end link bolt was just not tight enough and it was a loud click.
jonesg
Post by jonesg »
Now I see the tell tale drip drip , its coolant, radiator leak where it hit a jackstand.
Doing damage faster than I can fix stuff.
Ordering a new rad along with new tranny clips and seals.
Do I need to order more tranny fluid too ?
Rad is $214 but I see others at partsgeek for $109. Any good?
vtl
Post by vtl »
What brand? Valeo was the original, IIRC. I'd steer away from Chinese radiators.
Yes, buy couple of quarts. You will need 1/2, but it's always good to have a spare bottle or two.
DonnVa
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
I’ve been chasing down a front end clank over little bumps going slow out of my neighborhood. Pretty much everything is new on the XC front end. Complete strut assemblies, stabilizer links, wheel bearings, ball joints, control arms a couple years old. When I had it apart today I noticed my brake pads are a bit loose in the brackets. So I drove out of the neighborhood again, speeding up a little so I can apply the brakes when I hit the set of bumps and damned if the clanking went away. I guess I need new retainer springs unless you all have experienced this before. All other brake parts are tight. Slide pins are greased and tight.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
vtl
Post by vtl »
Did you install the springs correctly? Have pics?
