- DonnVa
- Year and Model: 2005 XC70
- Has thanked: 21 times
- Been thanked: 61 times
I installed a center speaker in my dash. I used a 4 channel amp and used the power and ground under the passenger seat for the factory amp option. Put a 30 amp fuse in location 11 on the drivers side fuse panel and got 12v to the connector. I pulled a left and right front RCA out of my Sony head unit and split them to 4. I used 2 channels to power the front L/R door speakers and bridged the other two outputs to the center channel. The rear speakers are still powered by the high level speaker outs of the Sony. I blended the gains on the amp to even out the sound. Sounds great for my purposes. The XC seemed to be lacking in sound especially in the front. I didn’t notice that in the S60 I had.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
- Has thanked: 2212 times
- Been thanked: 1853 times
I love watching others work..................!
2 jobs for the price of one! Bonus!!
- Has thanked: 987 times
- Been thanked: 1078 times
I hate do overs.jonesg wrote: 21 Aug 2022, 15:11 I drove over a dead coyote on the highway in millinocket and my exhaust repair is making noise again.
- Has thanked: 1613 times
- Been thanked: 4075 times
Named Wiley, no doubt
Beep beep
RoadRunneR model
Beep beep
RoadRunneR model
lrock
- Year and Model: 2001 v70 xc
- Has thanked: 9 times
- Been thanked: 37 times
stretched its front subframe between two trees with a 5 ton pullback ram while heating it with a Mapp torch and beating it with a hammer.
does VIDA include Tram dimensions ?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
we're gonna need pics for that.lrock wrote: 26 Aug 2022, 23:23 stretched its front subframe between two trees with a 5 ton pullback ram while heating it with a Mapp torch and beating it with a hammer.
does VIDA include Tram dimensions ?![]()
- jonesg
I started to install front wheel bearing, had to remove control arm tpo get to the 4 bolts holding the bearing carrier to the knuckle.
the old wheel bearing is very rough when spun so it was shot for sure.
Discovered the ball joint is loose and clicky so started to replace that too whilst i'm in there.
One of the bolts holding the ball joint flange snapped off.
i removed the whole knuckle and set it up in the vice, theres barely 1 thread proud of the knuckle, I plan to weld a nut to the threaded portion and see if I can turn it out.
Thats the plan.
Thats the plan.
