Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
Ahhhhh you mean usbjtag. Yes I have that and have successfully been able to take a dump of the f400 I think it is in a brick cem..Bryt wrote: 20 Aug 2022, 13:19 Ok thanks! There is no solution? I know U-Link nt works but not with obd
That's me experimenting.
oscilloscope
T5Luke wrote: 21 Aug 2022, 02:59 If someone needs i made a arduino nano soloution to read and write this type of cem by same pins, so no reason to buy further hardware...
Oh
I found a YouTube video of someone who has made a application which can edit the information within a cem dump. It looked interesting.
T5Luke
- Year and Model: S60 T5 2001
- Has thanked: 11 times
- Been thanked: 130 times
Here have fun with it:
Code: Select all
#define BKPT 4
#define RESET 5
#define FREEZE 6
#define DSI 7
#define DSO 8
static word CMD_READ = 0x1940;
static word CMD_GO = 0x0C00;
static word CMD_WRITEM = 0x1840;
char command;
int n_line;
void setup() {
// put your setup code here, to run once:
pinMode(BKPT, OUTPUT);
digitalWrite(BKPT, HIGH);
pinMode(RESET, OUTPUT);
digitalWrite(RESET, LOW);
pinMode(FREEZE, INPUT);
pinMode(DSI, OUTPUT);
digitalWrite(DSI, LOW);
pinMode(DSO, INPUT);
Serial.begin(57600);
while(!Serial){
Serial.println(F("Arduino CEM Reader, press:"));
Serial.println();
Serial.println(F("e: enter BDM Mode"));
Serial.println(F("l: leave BDM (experimental)"));
Serial.println(F("r: read complete memory"));
Serial.println(F("b: read Boot 0-3FFF"));
Serial.println(F("s: read security block 4000-7FFF"));
Serial.println(F("d: read car data 8000-1FFFF"));
Serial.println(F("f: read firmware 20000-7FFFF"));
Serial.println(F("c: BD32 Command Mode"));
void loop() {
// put your main code here, to run repeatedly:
if (Serial.available()) {
command = Serial.read();
switch (command)
case 'e':
Serial.println("Enter BDM");
digitalWrite(BKPT, LOW);
delay(10);
digitalWrite(RESET, HIGH);
delay(100);
Serial.println(digitalRead(FREEZE));
break;
case 'l':
Serial.println("leave BDM");
shift_BKPT_up();
delay(10);
wait_openchannel();
bdm_command(CMD_GO);
digitalWrite(DSO, LOW);
shift_BKPT_up();
break;
case 'r':
Serial.println("Read FLASH");
for (unsigned long offset = 0x0000; offset<=0x7FFFF; offset = offset + 0x02)
shiftRWord(offset);
break;
case 'b':
Serial.println(F("Read bootblock"));
for (unsigned long offset = 0x0000; offset<=0x3FFF; offset = offset + 0x02)
shiftRWord(offset);
break;
case 's':
Serial.println(F("Read securityblock"));
for (unsigned long offset = 0x4000; offset<=0x7FFF; offset = offset + 0x02)
shiftRWord(offset);
break;
case 'd':
Serial.println(F("Read cardata"));
for (unsigned long offset = 0x8000; offset<=0x1FFFF; offset = offset + 0x02)
shiftRWord(offset);
break;
case 'f':
Serial.println(F("Read firmware"));
for (unsigned long offset = 0x10000; offset<=0x7FFFF; offset = offset + 0x02)
shiftRWord(offset);
break;
case 'c':
Serial.println(F("BD32 Command Mode"));
serialFlush();
while(!Serial.available());
break;
default:
break;
case 'i':
Serial.println("wipe");
for (int i=0; i<=250; i++)
delay(1);
delay(1);
break;
void shiftRWord(unsigned long val)
word i;
word lowbyte = val;
word hibyte = val >> 16;
//Wait for DSO to get 0 => gets ready
wait_openchannel();
bdm_command(CMD_READ);
shift_BKPT_up();
shift_BKPT_up();
for (i = 0; i < 16; i++) { //HighByte
digitalWrite(DSI, !!(hibyte & (1 << (15 - i))));
shift_BKPT_up();
delayMicroseconds(1);
shift_BKPT_up();
for (i = 0; i < 16; i++) { //LowByte
digitalWrite(DSI, !!(lowbyte & (1 << (15 - i))));
shift_BKPT_up();
word W_Read;
for (i= 0; i < 1; i++) //Read Status Byte
//digitalWrite(BKPT, HIGH);
//delayMicroseconds(1);
//Serial.print(digitalRead(DSO));
for (i= 0; i < 16; i++) //Read back
bitWrite(W_Read,(15-i),digitalRead(DSO));
check_lzero(W_Read);
if (n_line <=6)
Serial.print(W_Read,HEX);
Serial. print(" ");
n_line++;
}else{
Serial.println(W_Read,HEX);
n_line = 0;
//return W_Read;
void write_Register(word cmd, unsigned long addr)
word lowbyte = addr;
word hibyte = addr >> 16;
wait_openchannel(); //Wait for DSO to get 0 => gets ready
bdm_command2(cmd);
shift_BKPT_up();
for (int i = 0; i < 16; i++) { //HighByte OFFSET
shift_BKPT_up();
shift_BKPT_up();
for (int i = 0; i < 16; i++) { //LowByte OFFSET
shift_BKPT_up();
void check_lzero(word W_Read){
if (W_Read < 0x10)
Serial.print("000");
return;
if (W_Read < 0x100)
Serial.print("00");
return;
if (W_Read < 0x1000)
Serial.print("0");
return;
void shift_BKPT_up()
void wait_openchannel()
while(digitalRead(DSO)!=0)
shift_BKPT_up();
while(digitalRead(DSO)!=1)
shift_BKPT_up();
void bdm_command(word command)
for (int i = 0; i < 15; i++) {
digitalWrite(DSI, !!(command & (1 << (15 - i))));
shift_BKPT_up();
void bdm_command2(word command)
shift_BKPT_up();
void serialFlush(){
while(Serial.available() > 0) {
char t = Serial.read();
oscilloscope
If any one was wondering here is the linkoscilloscope wrote: 21 Aug 2022, 03:02T5Luke wrote: 21 Aug 2022, 02:59 If someone needs i made a arduino nano soloution to read and write this type of cem by same pins, so no reason to buy further hardware...
Ohplease share , is it in github ? ,
- 8914 Views
Last post by RickHaleParker
- 8718 Views
- 27 Replies
- 27486 Views
Last post by cn90
- 10117 Views
Last post by jonesg
- 5357 Views
