Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Re: What did you do to your Volvo today? (now Sticky)
Post by Goupil »
Bled my brakes, got the dash back in again...Everything was fine until the last wheel bolt
I hope I will be able to get the rest out easily, not doing anything else car related today...
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Has thanked: 1497 times
Been thanked: 3810 times
Ouch on that wheelbolt.
Goupil
Post by Goupil »
I could already see myself buying left handed drills and stuff like that...I didn't even had to take the disc off and got it out by hand :lol:
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Just blasted off a can of AC duct (and general odor) cleaning mist in the car. I'm not following the instructions and airing it out after 15 minutes though since I'm now sitting on the balcony with a g&t and can't be bothered to walk down to the car again. I'm betting there'll be a lot of the "new car smell" in there tomorrow.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
bmdubya1198 wrote: 16 Jul 2019, 08:37It does. All you need is a factory amp of your choice and the wiring harness for it. I used the 4x50 watt amp that mounts under the passenger seat. You just need to run the wiring up through the console to the radio and plug it all in. Pretty easy job.
Do you know if the amp also works with 'normal' head units to give a bit of a boost?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Cookeh wrote: 18 Jul 2019, 14:32
Yup, you can connect the amp to the standard radios. I don't know about the SC-813, but the SC-816 has the connection for the amp. The two rectangular connectors connect from the amp harness rather than the car's harness, the amp harness includes two female connectors to accept the car's connectors, then the amp harness contains the same sort of connectors which plug into the radio instead.
I hope that made some sort of sense at least, lol.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Cookeh wrote: 15 Jul 2019, 06:54 What size hoses do you need for the 302mm upgrade? Looking to do it on my 850 soon - especially since my insurer doesn't classify it as a modification.
People get away with the standard hoses. The 302mm hoses are a smidge longer to account for the caliper now being a little farther away from the bracket at the end of the hard line. It's not that expensive to change them, but it can be kind of a pain if the fittings are corroded stuck. I replaced the hose, and in the process I had to cut the brake line and re-flare it. Not hard, but a $40 flaring tool set and a mess of brake fluid everywhere.
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
abscate wrote: 16 Jul 2019, 11:04
brunocerous wrote: 16 Jul 2019, 07:54 I cleared the P0600 code on my ‘00 V70 for the hour-plus drive to Queens, and it was fine. Then cleared it again for the return trip, and it didn’t reappear while driving. I’ve ordered the ECU removal tool in the hope that cleaning it might solve the issue.
In the meantime, Decided to buy my cousin’s 2003 Toyota Corolla with 45k miles — for which the dealer had offered $300. That’ll provide the lady of the house with air conditioning while I look for refrigerant leaks.
HEy - you shouldn't be ordering Volvo tools, Jersey. We have a programs for NY NJ friends and family.
Ill sign an affidavit that you can bring back her cool AC with a mere three more parts Volvos this summer.
Sounds like a deal! :)
bmdubya1198 wrote: 16 Jul 2019, 18:01 ... I guess that shows I have too many cars!
No such thing!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
brunocerous wrote: 20 Jul 2019, 08:36
No such thing!
True!
Rattnalle
Post by Rattnalle »
Rattnalle wrote: 18 Jul 2019, 10:32 Just blasted off a can of AC duct (and general odor) cleaning mist in the car. I'm not following the instructions and airing it out after 15 minutes though since I'm now sitting on the balcony with a g&t and can't be bothered to walk down to the car again. I'm betting there'll be a lot of the "new car smell" in there tomorrow.
Today, three days later, the perfume in the stuff is down to a more bearable level. It seems it's a good idea to follow the instructions and air it out straight away.. ;-)
Ten hour roadtrip tomorrow so I'll get some more out then.
