Vida CEM swapping
prometey1982
Year and Model: 2010 XC90
Been thanked: 5 times
Re: Vida CEM swapping
Post by prometey1982 »
T5Luke wrote: 26 Aug 2022, 14:24 If you have questions look into the p2 protocol documentation...
Hi!
Vitaly told me that others that CEM modules can me flashed without writing SBL to it. Is it possible? For ECM I upload SBL to it.
Они просто сдохнут, а мы попадем в рай.
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
The CEM -MY2004 has a primary bootloader inside with writing capabilities so for this you don't need a secondary bootloader...
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
I think prometey1982 meant to ask "modules other than CEM".
T5Luke
Post by T5Luke »
As far i know only the early modules support more primary bootloader functions, later they reduced them more and more and put the functions into to the secondary bootloader. The only other module i know that supports writing function in primary bootloader is the early CCM...
myname
Year and Model: 2007 XC70
Has thanked: 1 time
Been thanked: 4 times
Post by myname »
Hello,
Im sorry there's way too many pages to catch up on, I've probably only been through 40. Is there anyway to CEM pin crack with software only?
I have a 2007 XC70. I have a Dice cable, a regular USB to OBD cable and a laptop with Vida.
Im not super fluent with the super techy stuff thats been posted here.
Thanks
oscilloscope
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
Bryt wrote: 25 Aug 2022, 18:46 Ok thanks. I waiting for a cem i bought to test on before a do it on my car. My car has only one fob and i want to add one so i need it to add one more.
Tango can add keys via dump as far as I can tell?
T5Luke
Post by T5Luke »
myname wrote: 27 Aug 2022, 20:23 Hello,
Thanks
Yes there is...
Here get your UDS code by this:
https://filetransfer.io/data-package/sdnEjW7j#link
After that download your CEMs data, a full dump of your CPU flash by this:
https://filetransfer.io/data-package/FEduKEfj#link
DICE-206751, a charger for your computer and a charger for your car, can take up to 32h, depends where your code is...
Disconnect battery of your car for 10s to return into normal operating mode...
Works for all P2 cars from MY2006, VIN 10th pos needs to be 6 or higher...
repair
Year and Model: S60 II 2015
Has thanked: 2 times
Been thanked: 3 times
Post by repair »
T5Luke wrote: 26 Aug 2022, 03:54 The remote fob is stored in the UEM, you need a new fob with codes on package or a used UEM from same MY with used fobs. The transponders are stored in CEM.
I have information that some people do not use someone else's mirror at all to transfer the date of key fobs from it ... .
They only need someone else's keychain and without their own mirror ....
And they don't even open the keychain case at all ...
How can all this be true and purely technically possible?
Volvo S40, V40, V50, V60, S60, S80, V70, XC60, XC70, XC90, C30, C70 - Р1, Р2, Р3, 1998 - 2016 - language replacement DIM, ICM, PHM.
jaywats
Year and Model: 05/06 s60r
Has thanked: 14 times
Post by jaywats »
repair wrote: 29 Aug 2022, 04:24
Are you asking about key transponder or remote? Remote is stored in UEM
P2 - 06 S60 2.5 || 05 S60 2.5 || 02 S60 2.3
repair
Post by repair »
jaywats wrote: 29 Aug 2022, 12:48 Are you asking about key transponder or remote? Remote is stored in UEM
Remote
