Has thanked: 1505 times
Been thanked: 3818 times
Re: What did you do to your Volvo today? (now Sticky)
Complete hose refresh on Evita. Coolant change too. At 159,900 miles
Managed to use some 3/4 inch PEX clamps on 19mm hoses
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
I changed the turbo vacuum lines and did some tidying.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Had a good morning at the junkyard. Found a hood in my color with no dents at all. Also found a 12mm socket in the engine bay. Just what I needed to remove the hood. Washed the hood at the carwash on the way home and installed right away. Then I got ambitious and decided to swap my parts car taillights in. They are in such good condition all i had to do was clean them with some acetone and then spray a layer of clear uv resistant rustoleum. I don't think my lights have ever looked this good.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Nice find!
And WOW, those taillights were bad!
ZionXIX
Post by ZionXIX »
bmdubya1198 wrote: 05 Aug 2019, 18:02 Nice find!
What year did the plastic change in the tail lights? I was told the later years had a change to a more durable plastic.
I think next I'm going to swap out the front doors and heatgun/paint the trim and bumpers.
Still looking for a way to restore the headlight reflectors.
bmdubya1198
ZionXIX wrote: 05 Aug 2019, 19:16
I'm not sure. The V70 has the clear turn signals and those aren't prone to fading, but I don't know if the 855 taillights were ever updated.
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
I put the compression tester on the T5 and got just above 150psi (dry) on the first four cylinders and ~146psi on No. 5.
Took it for another spin and nearly froze from the AC.
BlackBart wrote: 05 Aug 2019, 12:33 I changed the turbo vacuum lines and did some tidying
That is quite possibly the spiffiest engine bay I've ever seen on a P80. Nice!
ZionXIX wrote: 05 Aug 2019, 13:58 Had a good morning at the junkyard. Found a hood in my color with no dents at all. Also found a 12mm socket in the engine bay. Just what I needed to remove the hood. Washed the hood at the carwash on the way home and installed right away. Then I got ambitious and decided to swap my parts car taillights in. They are in such good condition all i had to do was clean them with some acetone and then spray a layer of clear uv resistant rustoleum. I don't think my lights have ever looked this good.
Looks like night and day. What a great find!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Question. When you do a hose R/R And flush replace the coolant with genuine Volvo coolant, and your new coolant looks like 25% dilution yellow coolant, what’s the next step?
Answer. Flush out the old coolant you were saving on the shelf for Neil, and flush, and replace with green Volvo new stuff
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Changed valve cover gaskets on my bimmer. Also painted the covers black with VHT wrinkle plus.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Polished headlight lenses
BMW 540i 2002
S70 Base 2000
