Vida CEM swapping
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
myname wrote: 04 Sep 2022, 17:32 Here is the video. My car is a 2007 10th digit 7.
Dice seem to have probs by flooding bus with prog msgs, what is you dice?
All other programs that use dice should be closed...
5ft24
Year and Model: 2005 XC90 V8 AWD
Has thanked: 20 times
Been thanked: 12 times
Post by 5ft24 »
RickHaleParker wrote: 04 Sep 2022, 19:03
5ft24 wrote: 04 Sep 2022, 14:05 Doesn't run because I had used the DICE renumber in VDASH so VIDA wouldn't see the 206751... not sure why as I'm not planning on subscribing to do anything anyway... so now its 218475
VDASH has no way to return it to 206751...
Could the source code be modified to accept an alternative serial number or device name as an argument?
Just used NEO Hex Editor on the .exe going to check it out later today
ZRimaZ
Year and Model: XC60 MY2016 3.0 T6
Has thanked: 23 times
Been thanked: 13 times
Post by ZRimaZ »
T5Luke wrote: 05 Sep 2022, 03:24
...and the key removed? ;)
Have a nice day,
ZRimaZ
5ft24
Post by 5ft24 »
ZRimaZ wrote: 05 Sep 2022, 12:20
does the key have to be removed?
5ft24
Post by 5ft24 »
it talks now, but the PIN I know as good, as I sent it to D5T5 and it works in VDASH to change settings in the CEM, isn't working.
2005 XC90 V8
HwT
Year and Model: c30 2007
Post by HwT »
I have a 2007 C30 P1, when i crack the CEM pin, is it then possible to add new ignition keys? And how would this be done? You can do it via VIDA but you have to buy original key and also software module in vida. i was quoted 350 gbp by my local Volvo representative, also local locksmiths cannot do it.. I have teensy and Arduino, and DiCE available so cracking the CEM pin would not be a problem. Do you have add the keys via reprogramming the CEM in bench mode?
5ft24
Post by 5ft24 »
you have to have the 2 codes that come from the new key/fob and also the IMMO pin
konielian
Year and Model: 2010 C70, 2019 XC60
Has thanked: 1 time
Post by konielian »
Hello everyone!
Thanks to all the posts and contribute there I was able to assemble a Teensy 4.0 to decode the pin of P2 and P1, it was quite easy.
By the posts I have seen I was also able to read the Flash from a P2 V70 2006 and got the 320kb flash from it.
Now my question is how to write the flash back to the car?
Any Ideas?
T5Luke
Post by T5Luke »
5ft24 wrote: 05 Sep 2022, 12:51 it talks now, but the PIN I know as good, as I sent it to D5T5 and it works in VDASH to change settings in the CEM, isn't working.
2005 XC90 V8
The CEMs have 2 codes, the long 6 byte code you can crack by teensy, or the 3 byte UDS code you can crack by dice.
Both codes are different but have the same might... By the 3 byte UDS code you can read the flash by UDSreader and in flash you also find this 6 byte code...
T5Luke
Post by T5Luke »
This reads flash by 6 byte code:
CEM flash reader (6byte code).zip
(282.75 KiB) Downloaded 409 times
