Vida CEM swapping
PontusLSE
Year and Model: V70 2007
Post by PontusLSE »
prometey1982 wrote: 17 Sep 2022, 10:39
PontusLSE wrote: 17 Sep 2022, 10:05 I just noticed the last few posts in this thread. I do have a china version VIDA DICE 2014D, how can i find out if it is an DICE-206751?
Hi. You can run DiCE diagnosic tool and look DiCE number. Also you can open regedit and try to find 206751 value.
Thanks, it seems like my dice is the correct version according to the regedit values :) I will give it a try.
prometey1982
Year and Model: 2010 XC90
Been thanked: 5 times
Post by prometey1982 »
What about C compiler for m32c CPU? I installed Renesas HEW but didn't found samples for CAN.
Они просто сдохнут, а мы попадем в рай.
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
Samples are a lot to find in renesas pdf sample sheets. Sending can frames by c compiler is also easy. But don't forget you run on custom hardware with shared soft by sbl. It is easier to interact by assembler as by c compiler. I have a script that erases the part i want but in some cases it crashes and erases more even the pbl. I think something else is kicking in i need to find out...
NuovoRecord
Year and Model: 2004 V70
Post by NuovoRecord »
Wow, One year ago I asekd about the possibility of CEM hacking for pre-05 cars, and looks like we already have a solution! Now maybe I can finally activate my heated seats :)
Thanks to T5Luke and everyone else involved in this effort.
PontusLSE
Post by PontusLSE »
The UDS cracker seems to be working 👍 But how fast is it supposed to be? I am running this on a virtual windows 7 and I get a new seed/line every 4 seconds. Is that normal?
T5Luke
Post by T5Luke »
Every 0x100 (256 in decimal) pin tries 1 line is printed.
4 seconds one line means:
256 tries in 4s
pin code min is 0x000000, pincode max is 0xFFFFFF
0xFFFFFF/0xFF*4 = 263172s
263172/60/60 = 73h in worst conditions
My max was something around 32h with worst conditions, i get 1 line each 2s.
MiclMacl
Year and Model: 2008 XC90 Sport V8
Has thanked: 7 times
Been thanked: 3 times
Post by MiclMacl »
PontusLSE wrote: 18 Sep 2022, 09:21 The UDS cracker seems to be working 👍 But how fast is it supposed to be? I am running this on a virtual windows 7 and I get a new seed/line every 4 seconds. Is that normal?
Mine took around 7-8 hours I think. I did it in stages for a few hours at a time using T5Luke’s UDS tool. I made a note of where the tool had gotten up to, then closed down. I was then able to resume again from the address I had made a note of, at another time.
Never used a battery tender on mine as the car is in such a low power state with a good charge, but did disconnect the battery after each ‘cracking’ session to clear the car down. I think I had to clear DTC codes down, particularly the SRS Airbag from VIDA, but it worked like a charm and I could get the dump off successfully using the PIN.
rednasdees
Year and Model: 2004 V50 2.4
Post by rednasdees »
Some info to share,
I was trying to get the pin from my volvo v50 p1 from 2004, i used 2 versions of the cem cracker because i could not get a good result the first time.
The next link will give you guys the outcome of the 2 attempt i made. https://gist.github.com/rednasdees/6288 ... 43d5f75796
Does anyone here know of existing software which i can use to change settings in the cem ?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
rednasdees wrote: 19 Sep 2022, 10:03 Some info to share,
719 CEM. Read this: viewtopic.php?p=599631#p599631 May want to try sirloins version.
rednasdees
vtl wrote: 19 Sep 2022, 10:11
Yea that's what i did, and i got my pin as shown on the gist at the bottom of both crack attempts
