Uhhh... Didn't think about it. If the protocol allows for a unidirectional talk, the toggle is fine. I don't know, sorry. Maybe a guy smarter than me could answer your question.jcdillin wrote: 22 Feb 2021, 07:05 Do you need something like this to talk to it serially?
https://www.nxp.com/products/interfaces ... ce:MC33660
Or just toggle it?
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
- RickHaleParker
- Been thanked: 980 times
Until somebody adds support for K-line. Supported vehicles in the readme needs a revision. The K-line P2s are includes in the current readme. P2s before 2005 are K-line not CAN BUS.vtl wrote: 22 Feb 2021, 07:15Uhhh... Didn't think about it. If the protocol allows for a unidirectional talk, the toggle is fine. I don't know, sorry. Maybe a guy smarter than me could answer your question.jcdillin wrote: 22 Feb 2021, 07:05 Do you need something like this to talk to it serially?
Or just toggle it?
P2: (CAN BUS only).
2005 - 2006 S80
2005 - 2007 V70
2005 - 2007 XC70
2005 - 2009 S60
2005 - 2014 XC90
Active
Past
Past
- RickHaleParker
Teensy 3 K-line library on Github. The coders here might be able to extract some useful information from it.
Active
Past
Past
- RickHaleParker
And a resend every 5 seconds or less to "keep-alive" otherwise it closes.vtl wrote: 22 Feb 2021, 09:50 All P2s have CAN-bus, it just needs to be opened via K-Line. See a link to Olaf's blog on page 25.
Olaf wrote: I managed to find this conversation, containing advises to send a certain "keep-alive" message every 5 seconds to K-line (pin 7 on OBD-connector) to keep CAN bus interface open. Content is "84 40 13 B2 F0 03 7C", serial settings: 10800 baud, 8N1 and voltage range 0-12V (0V=0b, 12V=1b).
Active
Past
Past
vtl
Yeah, not a big deal at all.RickHaleParker wrote: 22 Feb 2021, 10:29 And a resend every 5 seconds or less to "keep-alive" otherwise it closes.
- RickHaleParker
I know, my electronics back ground is hardware. In electronics 5 seconds is an eternity.
Active
Past
Past
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
I'm still wondering why nobody is using DiCE to connect to the OBDII instead of trying to special build something else to do what It's already designed to do, which is to read/write to Volvo cars.
My authentic Volvo DiCE unit uses the above ARM Cortex-M7. I'm still reading through the instruction set, since I'm not familiar with ARM or Thumb, but it doesn't look too complicated to work with.
- RickHaleParker
You figure out how to measure the response times with a DiCE and pass on the information. I'm sure somebody here could take the information and write an application to crack the pin.gnalan wrote: 22 Feb 2021, 11:28 I'm still wondering why nobody is using DiCE to connect to the OBDII instead of trying to special build something else to do what It's already designed to do, which is to read/write to Volvo cars.
Active
Past
Past
- 9888 Views
Last post by RickHaleParker
- 10223 Views
- 27 Replies
- 31450 Views
Last post by cn90
- 12034 Views
Last post by jonesg
- 6998 Views
