Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
Folks happy new year, I trust everyone sticking too there new years resolution
oscilloscope
are you using Ghidra ?dikidera wrote: 30 Dec 2022, 00:06No that is a different pin. The WE pin belongs to the 29LV200BC flash chip. I've been away for a while due to personal issues and cannot come back to the project for a little while longer.oscilloscope wrote: 25 Dec 2022, 13:11According too the Hitachi data sheet for SH7055, it suggests FWE pin needs to be in a reset state to allow for read/write enable. Which then places it in programmer mode. , I am assuming that Hitachi version of the sh7055 is the same as the renesas. Before there transition. Assuming that's the pin you mean ?dikidera wrote: 24 Dec 2022, 03:42 I do not. I do have an oscilloscope, and I have noticed the WE pin going low every now and then when the ECU is operating normally. As soon as I start the SBL it remains HIGH, but that is because I have not issued any commands to it. I will have to solder a wire to it, but this time it will be thinner so if it decides to break, it won't take the pin off this time.
The AE command(write) is from the ECM PBL. The SBL just adds a few more commands, more specifically just F8(delete sector or entire flash). So yeah SBL is just an extension to the PBL.prometey1982 wrote: 26 Dec 2022, 08:45 I'm analyzing TCM's SBL at the moment. It's definely work by same algorithm as ECM flashing process. CAN sequence looks like on 0xE6 TCM:
1. Shutdown everything by 0xFF 0x86 request
2. Send 0xE6 0xC0
3. Send 0xE6 0x9C 0xFF 0xFF 0x82 0x00 // jump to addr 0xFFFF8200
4. Send 0xE6 0xAE with bootloader as payload
5. Send 0xE6 0x9C 0xFF 0xFF 0x82 0x00 // jump to addr 0xFFFF8200
6. Send 0XE6 0xA0 to jump execution point to addr from pt 5.
7. Send 0xE6 0x9C 0x00 0x00 0x80 0x00 // jump to addr 0x8000
8. Send 0xE6 0xF8 // erase memory block
9. Send 0xE6 0x9C 0x00 0x00 0x80 0x00 // jump to addr 0x8000
10. Send 0xE6 0xAE with flash payload
11. Send 0xFF 0xC8 to start add ECUs in normal mode.
I omitted the checksum check because I don't know algorithm for TCM. In my TCM's flash this check just disabled.
I didn't find 0xAE command processing ATM. Maybe additional bootloader should be loaded. But next command looks like enabling of flashing:Code: Select all
ROM:FFFF9666 flashing_FFFF9666: ; CODE XREF: sub_FFFF9596+C8j ROM:FFFF9666 mov.w #PJDR_W, r2 ROM:FFFF9668 mov.w @r2, r0 ROM:FFFF966A xor #h'40, r0 ROM:FFFF966C mov.w r0, @r2 ROM:FFFF966E mov.w #FLASH_FECS_B, r2 ROM:FFFF9670 mov.b @r2, r0 ROM:FFFF9672 and #h'FE, r0 ROM:FFFF9674 mov.b r0, @r2 ROM:FFFF9676 mov.w #FLASH_FPCS_B, r2 ROM:FFFF9678 mov.b @r2, r0 ROM:FFFF967A or #1, r0 ROM:FFFF967C mov.b r0, @r2 ROM:FFFF967E mov #0, r1 ROM:FFFF9680 mov.w #FLASH_FTDAR_B, r2 ROM:FFFF9682 mov.b r1, @r2 ROM:FFFF9684 mov.w #h'A5, r0 ROM:FFFF9686 mov.w #FLASH_FKEY_B, r1 ROM:FFFF9688 mov.b r0, @r1 ROM:FFFF968A bra loc_FFFF96A4 ROM:FFFF968C nop
Here are the ECM SBL commands, some...don't do anything from what I've seen, they just send a CAN reply back but don't really do anything else, the rest is still hard to decipher their purpose. The behaviour depends on FFFFDFA0 and FFFFDFA8, which I am still unclear WHAT they represent.
But like I said, might take a while after some events happened, you just can't have the same trust in your partner when they've done something bad behind your back.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
So I had another unfortunate event...I fried my Raspberry Pi after I was so close to modifying the car. And I fried in the car just as I was powering it up. All the work for nothing.
So now I have to ask, which proprietary tool can I buy, clone or not that can read and write Denso ECUs without removing it from the car, from the obd port?
I am hoping for the tool to also allow me to use vida. If not I have to buy another RPI.
Mine is Le.2 2005 so 500kbps bus.
oscilloscope
Iot terminal work well with these with the denso plugin sim.dikidera wrote: 07 Jan 2023, 10:08 So I had another unfortunate event...I fried my Raspberry Pi after I was so close to modifying the car. And I fried in the car just as I was powering it up. All the work for nothing.
dikidera
Quite a bit outside of my budget though.oscilloscope wrote: 07 Jan 2023, 12:28Iot terminal work well with these with the denso plugin sim.dikidera wrote: 07 Jan 2023, 10:08 So I had another unfortunate event...I fried my Raspberry Pi after I was so close to modifying the car. And I fried in the car just as I was powering it up. All the work for nothing.
oscilloscope
Maybe the clone kess might be able to do it.dikidera wrote: 07 Jan 2023, 12:43Quite a bit outside of my budget though.oscilloscope wrote: 07 Jan 2023, 12:28Iot terminal work well with these with the denso plugin sim.dikidera wrote: 07 Jan 2023, 10:08 So I had another unfortunate event...I fried my Raspberry Pi after I was so close to modifying the car. And I fried in the car just as I was powering it up. All the work for nothing.
- 9536 Views
Last post by RickHaleParker
- 9676 Views
- 27 Replies
- 29942 Views
Last post by cn90
- 11275 Views
Last post by jonesg
- 6376 Views
