The help file seems to be missing the actual articles outlined before. I have vida installed, but couldn't find these help files in C:/Vida.rkam wrote: 23 Jan 2023, 09:57 I believe J2534-2 is an extension to allow communication with more modules.
Here are some sections marked with J2524-2
https://github.com/diamondman/J2534-Pas ... 34_v0404.h
DiCE J2534 help file can also be useful.
J2534.zip
Some history and revisions:
https://www.kvaser.com/developer-blog/s ... on-part-1/
Vida CEM swapping
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
rednasdees
- Year and Model: 2004 V50 2.4
This one should have the can side of the components if i am not mistakenConstantinos wrote: 23 Jan 2023, 10:23 Good evening.
I have been for a cheap but effective way to unlock my cem pin through the obd2 port
I found the teensy 4.0 method but I'm having a hard time finding parts.
I found a pcb file which has all the wiring for the pcb as well.
However, I cannot find the bosch cf160 transceivers needed for the job.
Also, in the schematic on github, I can see that some resistors that need installing, but I'm not sure where to install them on the pcb.
The pcb link:
https://www.pcbway.com/project/sharepro ... 037d5.html
The github link: https://github.com/vtl/volvo-cem-cracker
https://www.waveshare.com/sn65hvd230-can-board.htm
Goodluck
dikidera
The final piece of the puzzle is to make my Python wrapper aware of baud rates which will also automatically handle pin switching, however there are some things which bother me.
Filters, timeouts, inrush messages saturating all rx buffers in our DLL...
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Mind sharing pictures of your hardware?coormis wrote: 24 Jan 2023, 08:03 hello, i try crack volvo xc90 2014 cem pin, but pin not cracked. hardware: teensy4, SN65HVD230, lm2596 dc-dc. attach log.log 01.24 not cracked.txt
can anybody help?
Thanks
5ft24
- Year and Model: 2005 XC90 V8 AWD
- Has thanked: 20 times
- Been thanked: 12 times
When I first started working on cracking my 2005 XC90 I would see all the zeros if I tried cracking with the key in position 2. If I left the key in position 1, or not use the key at all, it would crack the PIN just fine
Constantinos
- Year and Model: Volvo XC90 2006
So, with these, I don’t need the resistorsrednasdees wrote: 23 Jan 2023, 16:29This one should have the can side of the components if i am not mistakenConstantinos wrote: 23 Jan 2023, 10:23 Good evening.
The pcb link:
Goodluck![]()
rednasdees
If you look at the board in this link : https://www.waveshare.com/sn65hvd230-can-board.htm You can see there is a small 10 k resistor on the board next to the chip on the side of the board, at the top were the screws are there is a jumper which connect the 120 k resistor which is used if you have your unit on a bench and not in your car.Constantinos wrote: 24 Jan 2023, 09:54So, with these, I don’t need the resistorsrednasdees wrote: 23 Jan 2023, 16:29This one should have the can side of the components if i am not mistakenConstantinos wrote: 23 Jan 2023, 10:23 Good evening.
The pcb link:
Goodluck![]()
I myself used 2 of these with a teensy 4.1 on a breadboard you could also use a teensy 4.0 does not matter
- 9188 Views
Last post by RickHaleParker
- 9098 Views
- 27 Replies
- 28252 Views
Last post by cn90
- 10552 Views
Last post by jonesg
- 5706 Views
