Vida CEM swapping
rednasdees
Year and Model: 2004 V50 2.4
Re: Vida CEM swapping
Post by rednasdees »
Constantinos wrote: 24 Jan 2023, 09:54
rednasdees wrote: 23 Jan 2023, 16:29
Constantinos wrote: 23 Jan 2023, 10:23 Good evening.
I have been for a cheap but effective way to unlock my cem pin through the obd2 port
I found the teensy 4.0 method but I'm having a hard time finding parts.
I found a pcb file which has all the wiring for the pcb as well.
However, I cannot find the bosch cf160 transceivers needed for the job.
Also, in the schematic on github, I can see that some resistors that need installing, but I'm not sure where to install them on the pcb.
The pcb link:
https://www.pcbway.com/project/sharepro ... 037d5.html
The github link: https://github.com/vtl/volvo-cem-cracker
This one should have the can side of the components if i am not mistaken
https://www.waveshare.com/sn65hvd230-can-board.htm
Goodluck :)
So, with these, I don’t need the resistors
If you look at the board in this link : https://www.waveshare.com/sn65hvd230-can-board.htm You can see there is a small 10 k resistor on the board next to the chip on the side of the board, at the top were the screws are there is a jumper which connect the 120 k resistor which is used if you have your unit on a bench and not in your car.
I myself used 2 of these with a teensy 4.1 on a breadboard you could also use a teensy 4.0 does not matter
Constantinos
Year and Model: Volvo XC90 2006
Post by Constantinos »
rednasdees wrote: 24 Jan 2023, 10:11
Goodluck :)
Can I not use the con which I have linked?
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
Goodluck :)
Darn, so I am guessing if I have the 120 ohm resistor set and connect to the car, I will not get a good connection?
rednasdees
dikidera wrote: 24 Jan 2023, 11:33
I you stil have the cem in the car with evrything else connected you wont need those indeed, i think it might even mess up your cracking attempt :S
rednasdees
Constantinos wrote: 24 Jan 2023, 11:26
you can still order these boards, and desolder the chip and resistors and solder them on the pcb you found. if thats waht you were thinking about ?
dikidera
Post by dikidera »
rednasdees wrote: 24 Jan 2023, 11:42
No I am using a chinese MCP2515 board and just soldered the jumpers together to avoid using cables to short the jumpers as I was experimenting on the bench. I completely forgot about the possibility of this not working on the car.
rednasdees
dikidera wrote: 24 Jan 2023, 11:49
my message above was meant for someone else :D but uhm i gues you can try desoldering your jumper if you are using it in your car
Constantinos
That makes sense for the chip, but where would the resistor go on the pcb?
rednasdees
Constantinos wrote: 24 Jan 2023, 12:23
Actually funny does not look like it has one :? so i have no clue
Constantinos
Should I design my own con or should I just use a breadboard?
