Vida CEM swapping
brobert
Year and Model: 2006 V70
Has thanked: 9 times
Been thanked: 13 times
Post by brobert »
I've been wanting a cheap CEM to experiment on the bench.
My 2006 V70 has a 30728542 CEM-L but they are rare at my local boneyard.
Today, I have pulled (and oh what fun) a 30786890 CEM-H (L-shaped) from an 2007 XC70.
I will hook it up on the bench with 120 ohms terminations and get its PIN with the Teensy cracker.
I read on this site that CEM-H units can replace CEM-L units (but not the other way around):
https://www.datatransferring.com/cem-p2-2005
Can a kind soul confirm this?
While at it, I'd love to know more about the differences between CEM-L and CEM-H units.
I used to think that it was dictated by the CEM case shape but that's clearly not the complete story.
Maybe a CEM-H is a more powerful unit?
Thanks for the wisdom.
[Edit to add that another CEM lost a PIN poker game]:
found PIN: 34 28 59 56 36 52
PIN is cracked in 1667.82 seconds
Validating PIN
PIN verified.
duzi
Year and Model: S60
Has thanked: 18 times
Been thanked: 5 times
Post by duzi »
'L' - lack of components on the internal board side.
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
I have a p3 here , which I've been trying the cracker on and it doesn't recognise the module.
I was creating a beginning of the wiki , I can potentially still retrieve it via bdm
Pic for reference
brobert
Post by brobert »
Thanks & Wow, I never looked on the flip side of a CEM PCB...
What CEM part number is that and do you have a picture of the component side?
I understand making a CEM with less components to save money but stocking all these CEM models should come at a cost too.
Presumably they have done the math but in my opinion so far, I haven't seen real savings in components.
There could be some hard-to-spot differences in the chips however (amount of memory, speed grade, etc.).
Here's my contribution about extra components (compared to a CEM-L).
This is not my picture - I just annotated it.
duzi wrote: 29 Jan 2023, 05:43 'L' - lack of components on the internal board side.
2010 XC70 unknown CEM.jpg (186.87 KiB) Viewed 3369 times
hydziowy
Year and Model: 2016 XC70
Post by hydziowy »
Jackw16 wrote: 16 Jan 2023, 14:00 just an update, worked perfectly, got 909/s speed, took about 4:30hrs to crack a p3 cem from a 2014 v40, trying a 2016 v40 tomorrow, im thinking of doing a little wiki write up about this info etc does anyone mind? just some bench info and how to find and use the p3 branch as the info is spread about these 250 odd pages
Hi there! Did you try 2016 MY? How device works with it?
duzi
Year and Model: S60
Post by duzi »
v40 (2013-2016) cpu SPC560B60
oscilloscope
I'm messing around with the code , and attempting a read on the p3 cem I have here , currently with little success, I added a completely new line under p2 , with the part number which didn't work , now and I to understand it won't be able to find the part number as it doesn't know where it is stored in its hex location? , I scrolled down and found at line 463 - 470 looks like it's searching for data at locations, 0x88 , 0x00 , respectively, am I to assume if I can find the part number within a dump file , then populate the location it should be able to find it ?
rkam
Year and Model: 14473_96090_XC7007
Has thanked: 5 times
Been thanked: 25 times
Post by rkam »
0x88 is the command sent on CAN bus to request the part number from a controller while it is running its Primary Boot Loader.
Your P3 CEM doesn't use this type of programming mode.
oscilloscope
rkam wrote: 01 Feb 2023, 03:21 0x88 is the command sent on CAN bus to request the part number from a controller while it is running its Primary Boot Loader.
I see , so a p3 bootloader would need to be made , I had read on some dodgy site that the delphi module has some weird programming mode which is not very easy to access.
prometey1982
Year and Model: 2010 XC90
Post by prometey1982 »
Something was written here. Sorry.
Они просто сдохнут, а мы попадем в рай.
