StoneAge
Year and Model: 2001 V70ll
Post by StoneAge »
Hi all,
Newbie here with a very recently purchased V70 2.4D from 2001.
What l did today to my Volvo were:
-located the fluid leak on the power steering rack
-realised that the rack itself is kinda' loose and knocks a bit, although it isn't yet apparent while driving
-pressure washed the coolers as they were covered in literally a few millimeters / quarter of an inch oil+dust mix. So were the bottom of the engine and the subframe (which is Hungary is called a cradle)
-l would love to be right in thinking that l have a hole in the intercooler and that sprays the oil all over the show at the front. The cylinder head, the oil filter's surroundings, the turbo are all bone dry...
-l typed my VIN number in on different pages to see what l can find... the number came back as "invalid"
(YV1SW749242406075)
It's great to be here!
Regardinhos! :)
Nandi
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Try Skandix for your Vin, it shows a manual diesel V70 from 2004
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
I wouldn't think there's enough oil vapor in the intercooler to soak things, unless the turbo seals are failing.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
BlackBart wrote: 21 Sep 2023, 11:42 I wouldn't think there's enough oil vapor in the intercooler to soak things, unless the turbo seals are failing.
There's also a huge vapor intake via PTC (PCV). Especially relevant on old high mileage engines with bore taper and worn compression rings.
I had a brand new Volvo turbo and IC still got a lot of oil condensation. Sort of reduced to acceptable levels after rebuilding the engine, which included new piston rings and re-hone the bores.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I drove about 6-7 hours to college, and my volvo worked great! Averaged about 24mpg, which is lower than I expected, but maybe it was becasue the car was full of my stuff. After a summer full of repairs, hopefully it will be reliable until I get home.
2002 v70 X/C 288k miles
StoneAge
Post by StoneAge »
P80GLT wrote: 21 Sep 2023, 11:24 Try Skandix for your Vin, it shows a manual diesel V70 from 2004
It's interesting as -according to the vignette in the engine bay- it'a a 2001...
StoneAge
Post by StoneAge »
Apparently the issue had been neglected for several years and around 150k kms...
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
I found some accessories that I needed for my car on a car that just made it to the auto wreckers a day earlier. A nice dog grate, cargo cover, cargo net, and a OEM Volvo trailer hitch and factory wiring that I shipped to another MVS member yesterday.
dog grate.jpg (105.15 KiB) Viewed 588 times
2003 XC 70 (sold)
Has thanked: 311 times
Been thanked: 818 times
Post by erikv11 »
Dog gate that’s a grate pickup!
On the S60R: lifted the cowl, thoroughly cleaned up under there, removed the heater blower intake snorkel and washed it clean with warm soapy water, including completely cleaned the weatherstrip on the bottom. Overall removed a lot of accumulated grime and buildup. Installed some 1/4” adhesive rubber weatherstrip below the intake snorkel and snapped it back down into place.
Hopefully this solves the water ingress problem. Sunroof drains are not the source. Raining this weekend so I’ll find out.
P80GLT
Post by P80GLT »
@ Blacklab467 That's the first time I've seen another pocket net, it's a handy bit of kit for storing small items in the boot/trunk
2010 XC90 SE...SOLD
2005 V70 2.5T SE
