Remember there is a fixed filter in the reservoir that should be cleaned out when changing the PS fluidyanga001 wrote: 06 Nov 2023, 06:59 Will do a flush later and post up the contraption i use to flush out the system fully. Might make steering a little lighter.
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
There was a good writeup on a good method of flushing the PS fluid, basically engine off with front wheels off the ground and going left to right with the steering wheel slowly with the return line going into a catch bucket and keep the reservoir full. I did it twice on my car and the fluid is crystal clear. Check your fluid requirements, I believe you require Pentosin 202.
2003 XC 70 (sold)
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
I did the same with my partners RDX but found that removing the serpentine belt and putting an electric rachet on the pump nut can force all the old fluid out. We ran it on a low speed while turning the wheel and got the fluid completely clear. Her steering went from tough and noisy on the new pump to smoother than my carBlacklab467 wrote: 06 Nov 2023, 07:48 There was a good writeup on a good method of flushing the PS fluid, basically engine off with front wheels off the ground and going left to right with the steering wheel slowly with the return line going into a catch bucket and keep the reservoir full. I did it twice on my car and the fluid is crystal clear. Check your fluid requirements, I believe you require Pentosin 202.
Napa canada has some pentosin at a half decent price. I'll flush the screen when i take out the reservoir. I have a vac based pump which does wonders for that.
2008 S60 2.5T Auto (Sold)
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.Blacklab467 wrote: 06 Nov 2023, 07:48 There was a good writeup on a good method of flushing the PS fluid, basically engine off with front wheels off the ground and going left to right with the steering wheel slowly with the return line going into a catch bucket and keep the reservoir full. I did it twice on my car and the fluid is crystal clear. Check your fluid requirements, I believe you require Pentosin 202.
These two should help those interested in a power steering flush per wheel off the ground. Includes cleaning the reservoir.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
It's all back together now and I drove my V70 to work today for the first time since my daughters accident. It looks a little funny with the mismatched front bumper, but it will get painted hopefully soon. Feels good driving that car again, plus it releases our 240 from daily duty
. Good timing of everything because that car will be back in the garage for the winter soon.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 1611 times
- Been thanked: 4075 times
Good. Now we can fix Mathilda
Harvested ac compressor, alternator, PS pump from Shagg
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I accepted the fact that I need to change the alternator in my S60. Groaning like a pig and still occasionally get battery light on dash.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
yanga001
Touched up the rustproofing job done earlier in the month, ensured i had full coverage. The previous stuff stuck on well and distributed/crept into different areas.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The 2nd fuel tank door hinge repair failed in a month. Is anyone out there who has used rivets to fasten hinge to the body?
- MoVolvos
.xHeart wrote: 13 Nov 2023, 07:56 The 2nd fuel tank door hinge repair failed in a month. Is anyone out there who has used rivets to fasten hinge to the body?
I used fasteners. If your door pops open leave it alone unlike the zip tie and shrink wrap I tried to improve it with. Everything still working fine however.
(EDIT) Keep in mind this will no longer be a break away which Volvo intended the door hinge to function. Will have both door and body damage if caught on something.
viewtopic.php?p=611306#p611306
