- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Have you noticed any vibrations or increase in NVH since fitting the polybush upper mount? Mine is starting to go, and tempted to polybush it.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Nothing really bothering at idle compared to the stock bushing. It does get noisier over 3k rpm and under load tho, but it sounds kinda good
2.5T with a stock exhaust, recorded by my phone on the dash
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- Has thanked: 304 times
- Been thanked: 517 times
Started tearing down the XC today to reseal the timing cover. All that's left is to pull the valve covers, pulleys, crank pulley, and passenger side engine mount. Hopefully things continue to go smoothly. It's really not a bad job, just time consuming!
- Has thanked: 1500 times
- Been thanked: 3812 times
I worked in one of these with shockwave. It’s thirsty but a beautiful motor.
Thirsty indeed... it averages around 18 MPG. Hopefully a little more once this is done since I'll be replacing the plugs while I'm in here. I didn't want to do it sooner because the valve covers were leaking into them, and these plugs aren't cheap!
They look original at 164k miles.
It's incredible how small they are though... 60 degrees is tight for a V8. Still no room to work on it, but it's better with the intake manifold off!
Eh... I guess 18 isn't too bad. I average 19 in my R.
Peevarino
- Year and Model: 2009 XC70, 97 855R
- Has thanked: 28 times
- Been thanked: 3 times
Finally time and weather aligned to swap out my junkyard belt tensioner and new serpentine belt, finished before work this morning. Previous owner had put in the wrong size belt, too big by 12mm, the tensioner removed wasn’t stamped with any manufacturer, just a part number, and was easily moved tighter or loose by hand. See if it fixes the flickering at idle issue, but at least I know all that is proper moving forward.
(ETA: it did not fix that little idle flickering issue).
09 XC70 3.2
97 855R
97 855R
Got the timing cover gasket on today, just need to finish reassembly tomorrow. The job really isn't nearly as hard as people would make it out to be, but it seems I continue to make this discovery every time I hear that... usually the people saying it haven't done the job themselves!
It is, however, VERY time consuming... these V8s don't have much room to work around. But it's a good trade off... they're fantastic engines!
I will make a write up for this job in the next week or so, as I haven't been able to find one aside from those grim warnings from older Swedespeed threads. It will focus on the core of the work, I won't detail information on removing the power steering pump, pulleys, and whatnot as there are already good threads on that. Plus, it's self explanatory if you do this stuff regularly.
Fortunately VIDA has the basics in the procedure for timing chain overhaul.
Once that's done, I'll be installing a transmission cooler from a T6 and doing a fluid change. I figure since it's down, I might as well knock out as much work as I can. Plus, the trans cooler will help make it more suited for towing... I don't have any other vehicles to tow home my $300 Volvos so I need to keep this one in good shape
brunocerous
- Year and Model: 1998 V70
- Has thanked: 284 times
- Been thanked: 36 times
That is an awesome look inside the V8 version. Man, those timing chains!
Meanwhile, I just discovered the source of an occasional clanging sound from the rear of my Silver Bullet ('00 V70 MT) — the tailpipe hanger has rusted off.
So far, I've spent more time watching the video on this story on the 850 R than fixing the Silver Bullet. (It's cold out there!) https://www.autoevolution.com/news/1995 ... 40673.html
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
It's cool to look at, but I can't stand timing chains... belts are so much easier to deal with!
brunocerous
I could not possibly agree with you more. This is our albatross, er, VW EuroVan's VR6 during the timing chain job my brother and I almost successfully completed.bmdubya1198 wrote: ↑29 Jan 2020, 11:27 It's cool to look at, but I can't stand timing chains... belts are so much easier to deal with!
After my failed Saab 95 V6 turbo experience, I think five cylinders are all I can handle.
