2000 S70 Coolant Temp Gauge Fluctuating
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Do our engines have block drains?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
tjmartin317 wrote: 15 Jan 2023, 08:22
So I guess my real concern is if the concoction of coolant I’m running is a big issue? OEM is obviously best, but of course, my local Volvo dealer is closed on Saturdays. And happenstance forced me to use the coolants I did because I didn’t have a car to get anything else.
Part Peak, part BG, part Green Fram, and maybe a drop or two of OEM from days long gone…
But hey, the gauge does work again!
Shouldn't be a problem but here is what it all boils down to :wink: .
Has thanked: 1609 times
Been thanked: 4065 times
You can run water only around town for a day to get the right stuff unless you can’t protect it from freezing temperatures
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
454cid wrote: 15 Jan 2023, 20:24 Do our engines have block drains?
There is something that looks like it might be a drain on the back side of the engine near where the water pump bolts on. It looks like a supersized brake bleeder.
850oldschool wrote: 16 Jan 2023, 08:01
Give the drain 30mseconds of propane heat before you try to move it
Has thanked: 2199 times
Been thanked: 1852 times
As the guys say, there is a bleed screw/drain on the back of the block near/above the mount for the RH axle support bearing. Heed abscates advice before trying to loosen it and plenty of penetrating oil. This may help from Pelican parts:
https://www.pelicanparts.com/techarticl ... System.htm
If you look carefully at picture 5 you can just see the drain.
MoVolvos
Post by MoVolvos »
scot850 wrote: 16 Jan 2023, 17:02 As the guys say, there is a bleed screw/drain on the back of the block near/above the mount for the RH axle support bearing. Heed abscates advice before trying to loosen it and plenty of penetrating oil. This may help from Pelican parts:
Have used their tech articles for the C30 but didn't think to check for the S70. The 98-07 V70 is pretty close if not the same for many major parts.
https://www.pelicanparts.com/techarticl ... 0_Tech.htm
