2005 xc90 2.5T drives like a bounce house
nedc
- Year and Model: 1994 940T
- Been thanked: 2 times
My 2005 w/ 2.5t is a 7 passenger version w/ the 336 mm brakes so I assume it has the stronger rear springs. At any rate, it rides fine with the novo springs and regular Sachs shocks. If anything, it's still on the firm side.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I have the same 7 passenger, but I don't know much brake rotor size. In any case the ride is unbelievable compared to the blown nivomats. I'm not pulling a trailer or hauling thousands of pounds of gear. I would honestly be fine keeping the nivomat springs. But since I have new springs I want them to go in. Even if the dampening is less than ideal it feels fine to me. If the Sachs shocks wear our faster, it's a quick job to just change out the shocks themselves.nedc wrote: 21 Mar 2024, 08:45 My 2005 w/ 2.5t is a 7 passenger version w/ the 336 mm brakes so I assume it has the stronger rear springs. At any rate, it rides fine with the novo springs and regular Sachs shocks. If anything, it's still on the firm side.
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
Not necessarily. I read the suspension tag on a 2006 7-passenger with 336mm brakes and it had the lower-rated springs with Nivomat.nedc wrote: 21 Mar 2024, 08:45 My 2005 w/ 2.5t is a 7 passenger version w/ the 336 mm brakes so I assume it has the stronger rear springs. At any rate, it rides fine with the novo springs and regular Sachs shocks. If anything, it's still on the firm side.
Again, the only way to know is to read the suspension tag. This should be done before buying new rear springs.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.chitownV wrote: 21 Mar 2024, 21:45Not necessarily. I read the suspension tag on a 2006 7-passenger with 336mm brakes and it had the lower-rated springs with Nivomat.nedc wrote: 21 Mar 2024, 08:45 My 2005 w/ 2.5t is a 7 passenger version w/ the 336 mm brakes so I assume it has the stronger rear springs. At any rate, it rides fine with the novo springs and regular Sachs shocks. If anything, it's still on the firm side.
+1. Designed for and feel are two separate issues. For the same car one may feel it's firm while another too soft. If you buy a kit and the shocks are blown, warranty may require you to return the entire set. When it's discovered the shock were not installed with the correct springs...
- ZionXIX
Parts are already on the shelf waiting for a free weekend. I started with the rear suspension since it was in such bad shape. Next is front struts and all the associated hardware, mounts, etc.cn90 wrote: 24 Mar 2024, 09:10 At this odometer, you may as well do the front and rear suspension overhauls.
Info in forum.
- 724 Views
Last post by darrylrobert
- 18 Replies
- 2945 Views
Last post by misha
- 12 Replies
- 1157 Views
Last post by firstv70volvo
- 1116 Views
Last post by dikidera
- 671 Views
