1998 V70 NA RMS rear main seal - pull engine? Anything else while there?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Yep. Mine is an auto. Had zero problems.
1999 V70 GLT
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Great news!
I'll need more info about this.
I'll get back to you when time comes.
Not sure if i would go for a rebuilt or used good engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Andrew Vanis
Year and Model: 1999
Been thanked: 11 times
Post by Andrew Vanis »
Does engine breaking lessen (or reverse) the PCV system?
Was about to post that the 1200+ mile drive showed vast drip reduction with less that 1/4 qt oil disappearing.... Then we just did a could hundred miles in the mountains where I did an hour? of engine breaking and found the underside coated with oil down another 3/4 qt for a total on 1q low (2/3 low on the 1.5L dipstick range)
1998 V70 NA (11/97 build date) 230,000mi
Has thanked: 1609 times
Been thanked: 4063 times
Much less engine motion needed with the auto, you just have to disconnect the flywheel -flex plate bolts and then move it a bit, maybe only 2 cm or so? I’ve never done the separation engine in, so I’m guessing there.
Sveedy
Post by Sveedy »
As I recall, the distance needed is about exactly the distance between the crank pulley, and the passenger side inner fender as you lift the engine out. Just enough room to do it.
1999 V70 GLT
Caesium
Year and Model: 1999 V70 R AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Caesium »
Any update if it’s gotten better?
I’m in the same situation with my 99’ with a fresh PCV, 5w-40, and some AT-205. Just drove 4 hours today, we’ll see if in the coming days it gets better for me. Really hoping!
In the Garage
Viveka / 1996 850 N/A / Polar White + Oak / 154,9xx /
1999 V70 R AWD / Signal Red + Graphite / 171,8xx /
Previously Owned
Sada / 2011 C30 T5 M66 / Silver Metallic + Off Black / 129,7xx /
Blixt / 1996 855 R / Polar White + Dark Gray / 216,9xx /
Andrew Vanis
Caesium wrote: 31 Jul 2024, 20:20 Any update if it’s gotten better?
This is the last update I have from a few days ago posted above. Haven't driven it since.
Andrew Vanis wrote: 28 Jul 2024, 22:07 Does engine breaking lessen (or reverse) the PCV system?
