Which flavour of OBD-2 signal on 96 850 wagon?
- Has thanked: 17 times
- Been thanked: 35 times
Nice job!
Glad to hear that... You 're Welcome.Py wrote:Well, I did replace the transistors and... it works! I was just able to reset my "Service" dashboard light, and communicate with ABS, immobilizer and SRS modules (I do not have power seats, otherwise I'm sure I would have been able to deal with them...)
So, the hardware + software combination described by mtagoon does work on European spec cars, despite ilexa's claims to russel2419 that it won't!
Thanks again mtagoon!
Japanifold
- Year and Model: 96 850R
i have the same pin setup on my obd2. It seems some scan gauge do not work. In lamens term... what do i do?
- Has thanked: 2207 times
It is strange as I thought there was a problem with 95/96 cars getting an OBD2 read-out on a scanner, but then a friend told me he was able to on his 96 base model. However, there are some that like yours cannot be read.
There are a couple of ways, one is to buy a Vag-Com cable, access to a laptop and down-load vol-fcr software.
I understand you can also built a simple led bulb and wire system that can scan the codes like in the 93-94 cars that have the under hood diagnostic system.
The latter is highlighted on threads on MVS.
viewtopic.php?t=60660
The one below highlights software written by one of MVS's members and using an ELM 327 wireless plug-in
viewtopic.php?t=83145
- 3306 Views
Last post by Sommerfeldt
- 13 Replies
- 1657 Views
Last post by jantt
- 8924 Views
Last post by rhubarb
- 493 Views
Last post by rrres
- 17757 Views
Last post by combatkarl
