Timing belt weekend: '99 S70 non-turbo. Part 2.
This topic is in the MVS Volvo Repair Database » Project: Camshaft Pulley When Doing a Timing Belt
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
What i know:
It was impossible to remove the old belt! (Hence why all the write-ups suggest cutting it. The older the tool the better!)
I really tried to slip the belt off and around the nub, but it was impossible. And getting the belt on, around the nub, wasn't easy! But pulling the belt up and to the side, while pushing the bottom of the belt up and around, twisting the hard rubber as much as it could (the new Volvo belt doesn't budge more than a few mm) I finally made the clearance. I still don't understand how this makes sense: How can a belt go on but can't come off?
If anyone has a hard gas line there and wants to take some photos or film a video of me trying to solve this dilemma (and of course has a P80 with those hard gas lines!) let me know! I'm in NYC! 8)
Retired:
2015 Volvo S60, T5, 85K
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
My trick:
- Old belt...cut it to remove.
- New TB...wet it with a bit of water (the part that will slide through the nub), the TB will slide through the infamous oil pump cover nub very well...
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Of course always cut the old one off that makes removal trivial, and if you are careful instead of forceful then getting the new one back in isn't bad, you will get it in a few tries. Both have been discussed a billion times here and everywhere lol.
The only real question is about that hard gas line, I am curious about that one.
enesimi
Year and Model: Volvo s70 glt 2000
Post by enesimi »
Craigd2599 wrote:Gentlemen...you do realize there is a tool you can buy that resembles a golf tee that inserts into the hole in the crankshaft pulley and locks the crank at TDC? You pull the starter off and there is a cover you remove and the hole is right there. That and the cam locking tool from IPD and you are set.
...if only the shadetree guy who did my head gasket change had known this...
How you call this tool
goldmandan
Year and Model: 1999 S 70, 2000 V70
Post by goldmandan »
I am with Djzuelke, you can feed the Timing Belt up behind the harmonic balancer. Normally helps to have a second person pulling the belt up while you push it up behind the balancer. I is best to feed it through the right side (toward front of car) first as there's a dimple there that needs to be overcome in order to get the belt in the grooves of the sprocket.
Dan
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
Has anyone changed the timing belt on a 2000 with the variable valve timing inlet cam? What is different from the 1999 non-VVT documented here?
The British Haynes manual states that their timing belt change procedure is for pre-2000 without VVT and they can only assume that it's the same with VVT. I'd feel better knowing any differences.
Is there an online source for official Volvo repair guides which might have the procedure for the 2000 with VVT? EManualOnline seems really sketchy. Has anyone tried AllDataDIY? Thanks.
FireFox31
Has thanked: 1609 times
Been thanked: 4064 times
FireFox31 wrote: 21 Jul 2021, 20:18 Has anyone changed the timing belt on a 2000 with the variable valve timing inlet cam? What is different from the 1999 non-VVT documented here?
You have to setup the VVT HUB so that the hub is rotated full counter clockwise with respect o the cam, then align the marks as usual. You do this by rotating past the marks by 1/2 a rotation, then rotating backwards to match up the marks. From there, it’s business like the non VVT cars
I like Alldata as it’s web based so I don’t need to drag my msnual(s) between my 4 1999s. The new terms of service only allow access to two devices, a change from previous model, completely understandable.
FireFox31
Post by FireFox31 »
Thanks. Sounds like I should take off the cam covers on the back of the engine and check the slots in each to make sure they're horizontal. Sounds like a great idea to use the CTA 2864 tool to hold the cams in place at those slots. eEuroparts used to rent this $120 tool but now they don't. Does anyone here have one I could rent?
FireFox31
You don’t need the tool to change the belt, you just set the marks, remove the old belt, Idler,and tensioner, and reinstall.
