Oil leak from turbo
T64me
Year and Model: 04V70R/05S60R/07S60R
Has thanked: 6 times
Re: Oil leak from turbo
Post by T64me »
Great info! I've not replaced a PCV system yet so forgive my ignorance. Are you suggesting that I don't have to order a PCV kit - just order the hose, elbows and clamps you suggested?
Thanks very much for your input.
101
Year and Model: 98 V70GLT, 98 S70T5M
Post by 101 »
You would wind up buying most of the kit - minus the two long hoses you are going to be substituting.
That would be the separator (PCV box) itself, the hose that goes from the separator to the top of the engine, the hose that goes from the separator to the engine block, and the hose that goes from the bottom of the separator to the oil pan. You'll also need the clamps for those three hoses.
The other items you will need include an intake manifold gasket, and if you want - throttle body gasket, an oil dipstick tube o-ring where it goes into the oil pan and an oil cap gasket for good measure.
This is what I ordered last time I did mine. Use OEM parts ONLY for the three hoses!
1271988 PCV Oil Separator Box
8653339 PCV Hose "A"
1271653 PCV Hose "B"
1271654 PCV Hose "C"
9146266 Intake Manifold Gasket
976561 4 ea. Hose Clamps (PCV)
988026 2 ea. Hose Clamps (PCV)
977964 2 ea. Hose Clamps (PCV)
You'll be substituting your upgraded hoses for the other two longer hoses.
No doubt you will probably find other vacuum lines around the engine in questionable condition. Great time to address those as well.
There's lots of info on here on how to do the PCV system replacement. Plan on the full day if its your first time.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
T64me
Post by T64me »
Great info! Thanks very much!!! I'll report back when this is completed.
Switchemlee
Year and Model: 1998 v70 xc awd
Post by Switchemlee »
Hey what is the best way to completly clean the bottom of a 98 v70xc of oul from the bottom? I got oil on the bottom of my turbo and want to know a safe and efficent way to clean it thoroughly. Thank you for any advice:)
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
101 wrote: 28 Jun 2016, 10:46 What's the condition of your PCV system? You'd be surprised where these engines can seep oil from.
I chased a very similar oil leak on mine for a very long time. Your pictures look exactly like the bottom of my car once did. Once I redid the PCV system and mod to upgrade to the larger diameter hoses, all the leaks stopped.
What mod did u do. You have pics?
