1994 850 Turbo Engine Tick/Knock Between 1st and 2nd Gear
- Has thanked: 1611 times
- Been thanked: 4073 times
A brand new, Vice grip (tm) brand (no substitutes please) needle nose style is your friend on any obstructed bolt. I keep one in a baggy in the tool box for these contingencies. Before use, wire brush the head to remove surface rust. When you snap the vicegrip onto the head it should be taking most of your hand strength to close the vicegrip.
ManManOhMan
- Year and Model: 850 Turbo 1994
Thanks Abscate on the advice with the vice grips on the stripped torx bolt. I never thought about using a wire brush to remove the rust. For a little more clarity on the approach, you're saying to insert one side of the needle nose vice grip inside of the bolt and the other side of the vice grip on the outside of the bolt, squeeze and attempt to rotate it?
I got frustrated yesterday and walked off plus I had a couple of appointments I had to make. To be honest I didn't anticipate to finish Yesterday.
Grab the bolt on the outside, but you will need to get it on tightly
ManManOhMan
Abscate, thank you for the approach. I know this will most definitely help me. I'm going to get back to this repair Tomorrow, I've had so much lined up this week and every thing has been over frustrating to me because I got this repair on the back of my mind!
ManManOhMan
If the journal on the crank is scorn, where can I get an over-sized bearing to use, and the most important question is, how do I properly measure the journal of the crank after smoothing it down.
What do you guys think, even if the journal is scorn to a certain degree, do you think I can get by with just smacking another bearing in there?
Need some more advice, thanks!!!!
ManManOhMan
Sorry for not keeping everyone posted. I decided to replace the engine! Once again, thanks to all the member and those who contribute to this website.
If it wasn't for members like wheelsup and others, I wouldn't even considered replacing and removing this engine. When I first entered this forum, I didn't even know how to do a tuneup properly! I can't even believe it myself that I'm going to attempt this but you guys give me confidence!
Thanks to All,
Manmanohman
Thanks to All,
Manmanohman
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Best of luck. HUGE job but you'll definitely know that car inside and out after this.
'98 S70 T5
2016 Chevy Cruze Premier
- 16 Replies
- 2387 Views
- 1641 Views
- 1270 Views
Last post by jimmy57
- 1244 Views
Last post by precopster
- 26 Replies
- 5484 Views
Last post by rguzz
