when buying a used ETM what will work without a reprogram?
Start a thread in the P2 Forum (First one up top) if you want help troubleshooting - this is a bookmarked forum for reference stuff mostly - not huge traffic here.
william robinson
- Year and Model: 1995 850, 2001 s60
- Has thanked: 1 time
Hello.. do you mind if I ask what exactly I'm looking for in these volvo built ETM? I have a 2001 s60 non turbo thats getting near parked because of the etm.abscate wrote: 22 Jun 2022, 04:22 Vida will scrub the code, you can also check your work and see how close your sensors match.
The best solution to ETM based problems now is the late 2014 Volvo built contact less unit, on eBay for $150 or so for the patient.
Does the etm bolt on and plug on or what is needed? Many thanks in advance
It bolts onto the manifold with four m6 bolts, with 10 mm heads, it isattached to the big rubber snorkel.
- 1343 Views
Last post by precopster
- 2117 Views
Last post by matthew1
- 2579 Views
Last post by olddaddy
- 3048 Views
Last post by MadeInJapan
- 2628 Views
Last post by mrbrian200
