1997 v70r if i (accelerate)hard it loses power
chuffin hell
- Year and Model: volvo v70r
Just gone over all pipes another tcv off another car running 16psi and still cuts power
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
OK, if you're at stock boost levels, then you need to start over.
- Read your DTCs - your trouble codes.
- Check fuel pressures
- Check hoses again - even if your hoses are good, check that they haven't slipped off anywhere
- Swap for known good TCV, or an HD
Etc, etc. but start by seeing if you've got any codes!
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
chuffin hell
Hi
I've just been over it again and I have found a problem
If I try and get a vacuum from cbv I cant I just keep sucking if u understand me
Sommerfeldt
Hmm... Not sure. You're saying it can't hold the vacuum?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 2210 times
Hi Adam,
Back from Scotland and good to see Sommerfeldt has been taking care of you.
If you are running 16psi, the standard TCV is no good for that level. About 14psi and above it becomes erratic.
Sounds like you may have found a possible culprit as previously suggested. I you can't maintain a vacuum on the CBV, than chances are it has a hole or tear in it. If your car has a 16T turbo you can replace that without removing it. On the later larger 19T you have to remove the turbo to get one of the cover bolts out. Again, worth looking for a stronger spring for that. Check on IPD web-site.
chuffin hell
Thx guys goin to take cover off tomorrow will keep u posted
chuffin hell
Cbv replaced guess wat
Same problem
Same problem
chuffin hell
So update
Tcv
Cbv
Leads
Coil
Filter
Plugs
Vacuum pipes
All replaced
And still losing power
If I accelerate hard it goes fast and then just cuts if pedal still down it goes again but then loses power
Tcv
Cbv
Leads
Coil
Filter
Plugs
Vacuum pipes
All replaced
Sommerfeldt
If you're still at stock boost levels, and haven't cranked it up again, I'd almost be willing to step out on a limb here and call your chip into question. That said, I've very limited experience with chipping, since I've never had it done to any of my bricks.
Someone more experienced with chips would have to chime in, but if your car's cutting out even though everything is new/checked/working, then that still means engine control issues, at least as far as I can see...
In the mean time, also check throttle control systems, just to make sure this isn't something mundane and mechanical, such as a throttle wire it something like that.
The car still doesn't throw any codes?
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
chuffin hell
Hi no codes am just going to do fuel pressure check again
See if it drops wen the problem occurs
- 1416 Views
Last post by hvsk
- 1080 Views
Last post by xHeart
- 602 Views
- 20 Replies
- 5063 Views
Last post by guidowitz
- 1371 Views
Last post by sbattaglia
