1990 740 gle gas delivery problem?
joedrt77
Year and Model: 1990 740 gle
Post by joedrt77 »
New coil, new power stage, new fuel pump relay, still no 12 v. to fuel injectors and no start.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Have you already checked the radio suppression relay and it's wiring connection? This is what supplies 12 volts to the injectors.
1988 Volvo 760 Turbo Wagon
joedrt77
Post by joedrt77 »
have 2 side by side, swapped them, they both click, jumpered the connection, that is the two thick wires, still no 12 v. at injector connector. Thinking that means no signal from fuel injection module, not sure how to test it with multimeter or my regular non-led test light, don't want to blow anything on the module, can not find a whole test procedure or tutorial.
joedrt77
Post by joedrt77 »
I have an 02 fault but It doesn't seem like that would keep it from starting, not sure tho?
joedrt77
Post by joedrt77 »
( I jumpered the rsr relay then tested for 12 volt again at fuel inj. connector still no steady 12 volts, on one side I get like 3.5 volts then goes to 0 quickly, then when i take off the test lead and touch it back to same point on f inj. connector it reads 0 not 3.5 just 0, other side is 0, but as i understand one side will be 0), was at one point getting that BUT now there is no voltage reading at all at the f i connectors.
joedrt77
Post by joedrt77 »
the coil I'm using has 1.8 on the primary resistance, according to the volvo specs. the coil primary resistance should be .6 to .9, my spark is orange, not using spark tester just using spark plug for testing spark, being 1.8 instead of .6 to .9 is that a problem or is it within tolerance? thanks.
lummert
Post by lummert »
joedrt77
Post by joedrt77 »
Was trying to follow a test procedure, hooked up test light to 3 on rsr relay connector, it lit up as expected, then on the other big wire on same connector, it says it's supposed to blink while engine is cranking but no blink and no light up at all.
joedrt77
Post by joedrt77 »
Thanks for the help, put those new parts on, cleaned and fiddled with the rsr and got it running again, might still be something intermittent going on but at least it will start, was quite a puzzle.
joedrt77
Post by joedrt77 »
Thanks again Lummert and regina 93, you guys were right on the money, great advice.
