I think it's pretty clear that a Gates water pump is a 20K water pump. A stopgap if you need to get on the road for a little. But anything more than that and you're asking for trouble. I wonder how long the water pump made noise for before it went out like that. I heard one of Robert's videos of a water pump that was making noise (at least I think it was Robert's...) and the impeller rubbing against the housing really makes a distinct sound.
Do we have an MVS consensus on the longevity of a Hepu water pump?
'96 Platinum Wagon: broken timing belt. 7:18am Topic is solved
Failed Water Pump Causes Timing Belt Failure
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Retired:
2015 Volvo S60, T5, 85K
- Has thanked: 311 times
- Been thanked: 817 times
I fixed that for ya.mecheng wrote:Everything URO sells is utter crap.............
- theWIFES_S70
Oooooh, but it comes with bolts! It can't be that bad!
Retired:
- Has thanked: 316 times
- Been thanked: 531 times
My cousin has a Gates pump.... that's interesting.theWIFES_S70 wrote:I think it's pretty clear that a Gates water pump is a 20K water pump. A stopgap if you need to get on the road for a little. But anything more than that and you're asking for trouble. I wonder how long the water pump made noise for before it went out like that. I heard one of Robert's videos of a water pump that was making noise (at least I think it was Robert's...) and the impeller rubbing against the housing really makes a distinct sound.
I'm very interested about the Hepu pump. From what I've seen, it looks like a good alternative to the Aisin.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
The best and unbeatable alternative for Aisin is SKF and then Hepu.
Rspi said that he had seen a Hepu that failed in 40k on these cars but lasts forever in rwd cars...i don't know..
It's a lonely example....other members who have Hepu complained about gasket leak in a pretty short time after installation.Could be that it was a miss during installation..that old gasket didn't removed completely.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
That's an easy mistake as far as the gasket not being fully removed, but you need to be careful with such a vital component. Much more of a pain having to replace the pump (or having it fail on you) than it is to replace, say, an oil filter that's leaking because the old gasket was still on the engine.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Men, I even dislike those black gaskets. They are a 60 minute clean up when removed, about 100 pieces.
Why even consider an "alternative" when you have access to the best, Aisin. Hey, I'm doing a 4 hour job on a critical system of the engine, I think I'll buy xyz and see if it makes it 70,000 miles...
I run Aisin pumps 10 years regardless of the miles. Mine failed in 20 years, 258,000 miles. I've seen others fail in 2 years, less than 35,000 miles... leaking. The one referred to above had about 12,000 on it if my memory serves me correct. The shaft was bouncing around so much it was making the head noisy. It actually sounded like a cam was loose, bouncing around in the head. When I pulled the cover and seen it, I screamed at Buster Brown, shut it down. I thought the shaft would come apart at any second, destroying the head.
A year or so ago I was about to leave my daughter in Ohio, changing a cam seal and seen the water pump leaking. Called the dealer and they wanted $285 for the pump. Went to the junkyard and found one with a 2 year old date on it. I feel much better about a $6 junkyard Aisin pump than anything in the local auto parts stores. Besides that, I needed to hit the road ASAP, not wait 3 days for a part to arrive from a Volvo parts supplier.
So, yes I do pull newish Aisin pumps from the junkyard and order the green seals from parts suppliers. Works for me, and those I help.
- rspi
Contact rspi..
YouTube links not working...
- rspi
Contact rspi..
On this video it looks like the gasket says ...SKF...
- misha
No....it says gasket with some missing letters....if you look closer.
Skf gasket which comes with a pump is not green.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 5225 Views
Last post by jimmy57
- 23 Replies
- 17043 Views
Last post by jonesg
- 20 Replies
- 17348 Views
Last post by Hurtfeelings
- 40 Replies
- 7931 Views
Last post by matt122s
- 3950 Views
Last post by rspi
