Timing Belt Moving?
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Same procedure, you just turn the crank by hand so that the timing marks line up properly while reinstalling the new belt. There's no room for error here: if you get something wrong, such as improper torque on various bolts or sub quality aftermarket pulleys/tensioners that are prone to failure and the new belt comes off you'll effectively destroy the engine.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Did you fix this problem after installing the new belt kit and wp?
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
jking4020
Year and Model: 1997 850, 2001 v70xc
Been thanked: 3 times
Post by jking4020 »
It's just where your timing belt is sitting in accordance to where it is on the sprockets. it's not a big deal but if you're concerned have someone help you and take some slack off of it and make sure the belt is setting toward the back or front of each sprocket. in other words make sure the belt is in the exact same position on each sprocket. Then while it's running you won't see it going back and forth like that. Make sense? and no power before 2000 RPM's could mean you need wastegate adjustments on your turbo.
jking4020
Post by jking4020 »
And yes correct torque and putting back your pulleys is incredibly important! I did this job to my old XC70 and was careless about torking everything. And did not replace my timing belt tensioner. It resulted in a $300 tow from over 50 miles away after the car bent valves and completely died. 😣😟
