1998 V70 GLT Stops abruptly after new head
dobrosailor
Year and Model: 2002 Vovlo C70
Has thanked: 5 times
Post by dobrosailor »
Btw no codes thrown this time...
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I think there is a rivet holding the strap over the ECU box that needs to be drilled out. Once the strap is off, just pull the tabs and lift the cover off. Then pull up the lever on the ECU and it'll pop right up. Much easier than the ME7 ECUs!
Have you replaced the coil? I would definitely think that in this case it's a signal issue to the coil, but you never know... maybe the coil is just dead.
I just remembered you had P1617 showing before, I would remove and reinstall the ECU and TCU before doing anything else. Just make sure the connectors are clean. Don't use any chemicals to clean them.
