$6500 for repairs?
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Didn't smell like rotton eggs or gassy.. There is the chance that an injector plugged up. They did something that didn't last very long as you said it ran good for a short time and then began missing again. This might be in line with an attempt to clear a fouled injector that may simply need to be replaced rather than cleaned. If some grit got into it or the pintle is damaged they can stick open, closed or part way. This is of course something to consider *after* you've checked/verified that all the air hoses/intake is tight and sealed up.
AndyG
- Year and Model: 2011 XC90
- Has thanked: 16 times
I just ran a bottle of Cataclean with only 4 gallons in the tank and ran it hard on the interstate until empty. Monitored O2 sensors and cat afterwards. Sensors and cat temp are all within spec. Check engine light is off. Going to monitor for a week or two. Fingers crossed!
- 1893 Views
Last post by hermechanic
- 18 Replies
- 6179 Views
Last post by AlexBHughes
- 37 Replies
- 7286 Views
Last post by rgk
- 939 Views
Last post by misha
- 828 Views
Last post by 93Regina
