Here are a couple of pictures of the mats when I bought them, they literally were ready for the bin but as replacements are no longer available needs must and they were repaired
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Acquired a 2009 S60 2.5T AWD with 115K miles.
Project 2009 S60 2.5T AWD
viewtopic.php?t=103734
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
Cleaned my MAF sensor today. Was a PITA as the downstream hose was stuck to the sensor housing. I do not posses 5 point security bits so i just sprayed from the front and left it for 20 minutes to dry off.
2008 S60 2.5T Auto (Sold)
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 604 times
IPD USA toe rods after 6.5 years in New England:
Had to use pipe wrench to turn them in frozen threads. The threads were liberally lubed with marine grease last time I was touching them, they still froze. All the time.
- Has thanked: 1498 times
- Been thanked: 3810 times
I do not miss all the salt and liquid acid used upstate , not used down here on Long Island
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
Looks like they were dirty but otherwise fine except for the worn soft pads. Replaced with indoor/outdoor carpet?
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
- P80GLT
A most uneventful Christmas trip in the V70 this year, yes the wind was blowing a hooley as we drove north of Spean Bridge without incident as the car took it all in its stride on 23rd. Then to the 24th I went for a drive to Glen Nevis and Glenfinnan to get me out the house for a break...
Glen Nevis
Glen Nevis
- P80GLT
-5°C this morning and with the heavy rain last night the door handles had frozen, the door seals however were fine as I had coated them with Gummi Pflege a few weeks ago. Once the car was opened I checked the oil and water level and stuck my hand under the turbo to check there was no more oil leaks after its rebuild.
Clicked over 66,666 coming down the loch side just south of The Pulpit on the A8
Der Teufel steckt im Detail
The view I woke up to this morning
- Has thanked: 927 times
- Been thanked: 1000 times
My V70 experienced about the same temperature this morning, although I called it 24 F. It turned over just fine and after scrapping some frost, we went out for breakfast before dawn.
This afternoon it got a much needed transmission drain and refill of 3 quarts. It was a nasty color.
