Yesterday I swapped my corner light indicators with aftermarkets from 1aAuto (pnP wanted $20 for patinea'd units). They don't fit well and the tabs broke off immediately, but 1aAuto issued a full refund without requiring me to send them back, which was nice of them.
Also swapped the trunk struts, which seems trivial, but makes the car feel shockingly new lol.
The biggest thing from yesterday was I found a bulge one one of my all season tires when I was switching them on. Two were already due to be switched being 7 years old, so I figured I'd get a better deal buying a full set. So I swapped all 4, and luckily I spring for the road hazard package because later that night my back wheel got a puncture and ran flat. Actually my first flat ever! They're swapping the tire with a brand new one for $14 tomorrow
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
07 V50 T5 AWD M66 ~146k miles
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Got the 302s installed on the front of the wife's '97 855 GLT.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Finally got my rusty trailer hitch removed. The last 2 stripped bolt put up a good fight and I had to get the angle grinder out
When removing the hitch it got caught in the exhaust, put quite some weight on it and the p.o amazing welds made some rather bad cracking noises
So right now I'm hoping it holds for now and I have a Ferrita catback on the way
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- Has thanked: 927 times
- Been thanked: 999 times
I cleaned brake dust off my wheels.
Hey, I did something.
- Has thanked: 1497 times
- Been thanked: 3810 times
Is there away to glue this back on and get more brake pad life?volvolugnut wrote: ↑07 Apr 2020, 17:24 I cleaned brake dust off my wheels.
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
You mean brake pads arent a lifetime part?abscate wrote: ↑08 Apr 2020, 04:50Is there away to glue this back on and get more brake pad life?volvolugnut wrote: ↑07 Apr 2020, 17:24 I cleaned brake dust off my wheels.
- smacknab
What were those engineers thinking??
- ZionXIX
I'm waiting for a manufacturer to suggest lifetime engine oil with no changes needed. That will be a spectacular disaster.
- jmcguire
- Year and Model: 1996 850 Sedan
- Has thanked: 19 times
- Been thanked: 9 times
The 850 passed state inspection and emissions testing with flying colors at 65328 miles on the odometer.
At 65450 miles the engine cooling fan wasn’t shutting off when turning the ignition off. It would continue to run for about a full minute before turning off. I replaced the fan relay and the coolant temperature sensor. While doing the work I flushed the cooling system and replaced the Stant thermostat with a genuine Volvo one.
One note... when I first started the car after replacing the sensor and relay the fan kicked on immediately. I shut the car off and it continued to run. So, I restarted the car and allowed it to idle until eventually the fan turned off by itself and it is now cycling perfectly. Might have been stuck in mid-cycle and needed to reset.
1996 850 Sedan
