Here's a pin from 2005 XC70 dump (327680 bytes), at offset 0x4E000:
Vida CEM swapping
- TonyToronto
- Year and Model: 2007 XC90
- Has thanked: 5 times
Thank you. Address 0x4E000 blank, all FF's. This CEM has MC32 MCU, can't seem to find the location for those. I used Autel programmer, VVDI failing to read this mcu. I have feeling it doesn't do a complete read. I've read 2 different CEM's and both read the same way. Seems to be enough to make keys, but maybe not enough to read CEM pin, or i just missed it, period.vtl wrote: 16 Oct 2023, 07:52 Here's a pin from 2005 XC70 dump (327680 bytes), at offset 0x4E000:
thanks again.
edit: 0x4e000 not blank, just doesn't seem to contain pin, sorry, lack of sleep
- CEM-TYPE4_FLASH.rar
- (122.96 KiB) Downloaded 93 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Check at 0x7e000.TonyToronto wrote: 16 Oct 2023, 08:10Thank you. Address 0x4E000 blank, all FF's. This CEM has MC32 MCU, can't seem to find the location for those. I used Autel programmer, VVDI failing to read this mcu. I have feeling it doesn't do a complete read. I've read 2 different CEM's and both read the same way. Seems to be enough to make keys, but maybe not enough to read CEM pin, or i just missed it, period.vtl wrote: 16 Oct 2023, 07:52 Here's a pin from 2005 XC70 dump (327680 bytes), at offset 0x4E000:
thanks again.
- TonyToronto
When you know, you know!! yup, it's there.vtl wrote: 16 Oct 2023, 08:17Check at 0x7e000.TonyToronto wrote: 16 Oct 2023, 08:10Thank you. Address 0x4E000 blank, all FF's. This CEM has MC32 MCU, can't seem to find the location for those. I used Autel programmer, VVDI failing to read this mcu. I have feeling it doesn't do a complete read. I've read 2 different CEM's and both read the same way. Seems to be enough to make keys, but maybe not enough to read CEM pin, or i just missed it, period.vtl wrote: 16 Oct 2023, 07:52 Here's a pin from 2005 XC70 dump (327680 bytes), at offset 0x4E000:
thanks again.
Thank you so much, you may have just avoided a perfectly good XC90 from going to the crusher!
rkam
- Year and Model: 14473_96090_XC7007
- Been thanked: 25 times
M32C comes in different Flash sizes.
320kB starts at 0xFB0000 with size 0x50000
384kB starts at 0xFA0000 with size 0x60000
512kB starts at 0xF80000 with size 0x80000
From the CPUs point of view, the pin is typically 0x2000 from the end at 0xFFE000.
- TonyToronto
Hi, is the pin sequence as displayed, or like on some other ones, there's a sequence to it? can't find much info with M32c
EDIT: i found the answer in the volvo-cem-cracker. If helps anyone: (p=position in flash file)
p[3] = pin[0];
p[1] = pin[1];
p[5] = pin[2];
p[0] = pin[3];
p[2] = pin[4];
p[4] = pin[5];
After having the right sequence and proper passwords was able to read Flash and EEprom of the damaged CEM and Clone it to a used CEM.
Thank You guys so much,
tony
p[3] = pin[0];
p[1] = pin[1];
p[5] = pin[2];
p[0] = pin[3];
p[2] = pin[4];
p[4] = pin[5];
tony
vtl
Yes. Find a line with your CEM number in sources, last number in array would indicate a shuffle order.
Shuffle orders are kept in
Indexing starts from 0. So for shuffle order 1 the order is 3, 1, 5, 0, 2, 4.
Code: Select all
{ 30795115, CAN_500KBPS, 1 }, <== 1 is shuffle order
Code: Select all
unsigned char shuffle_orders[4][PIN_LEN] = { { 0, 1, 2, 3, 4, 5 }, { 3, 1, 5, 0, 2, 4 }, {5, 2, 1, 4, 0, 3}, { 2, 4, 5, 0, 3, 1} };
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
In 2005+ models with the L-shaped CEM, is it still possible to emulate PHM module and write to the DIM?
Look at end of post for L-shaped CEM and PHM.
I do
send_can_message3([0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05], arbid=0x0220200E) #announce PHM
then I also do
send_can_message3([0xA7, 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06], arbid=0x00C00008) #start writing
send_can_message3([0x21, 0x07, 0x08, 0x09, 0xA, 0xB, 0xC, 0xD], arbid=0x00C00008)
send_can_message3([0x65, 0x07, 0x08, 0x09, 0xA, 0xB, 0x00, 0x00], arbid=0x00C00008) #end writing
Alas, nothing.
I am sending on low speed bus with 30ms delay between messages unfortunately nothing is happening.
Unless of course this is a limitation of the bifuel model and PHM is disabled by CEM configuration.
Addendum:
I decided to look for config dumps and found a bunch from the S60r standalone DIM cluster.
When using the CEM config message ID 1017FFC, I managed to figure out various config stuff
send_can_message3([0x13, 0x01, 0x01, 0x01, 0x01, 0x02, 0x03, 0x03], arbid=0x01017FFC)
0x13
0x01
0x01
0x01
0x02
0x03 - By changing this byte between 0x01 and 0x04 I can enable Instant Fuel Consumption, AVG fuel consumption and AVG speed. This was previously not possible on BIFUEL models according to Volvo Dealer information
0x03
Still wasn't able to write to the DIM though.
Addendum 2:
After googling I found this https://www.swedespeed.com/threads/cust ... im.659433/ and this https://github.com/larslego/Volvo-PHM/b ... isplay.cpp claiming to work on 2005-2009 models .
And it works.
I do
then I also do
Alas, nothing.
Addendum:
0x13
0x01
0x01
0x01
0x02
0x03
Addendum 2:
And it works.
oscilloscope
- Has thanked: 27 times
- Been thanked: 11 times
Folks is there volvo v50 sid803a config & vin
editor ?
editor ?
oscilloscope
Furthering on from my investigation with this Siemens sid803a , I wanted to see if I could decode the flash. And see the config (if any) I took a dump of the flash and could see somthing which looked remarkably like a VIN number. I will note it down and see if its genuine. , I did some very basic searches for the ecu and suspected config data and I couldn't find anything of any substance. My search continues , any suggestions on what I can use to decode it into readable format I'm all ears.
- 9561 Views
Last post by RickHaleParker
- 9715 Views
- 27 Replies
- 30068 Views
Last post by cn90
- 11327 Views
Last post by jonesg
- 6432 Views
