If you bought from reputable supplier, likely good. Any other place these days, roll of the dice.
Also, search for different code, the P1 branch. helped me with stubborn P1
Vida CEM swapping
- TonyToronto
- Year and Model: 2007 XC90
- Has thanked: 5 times
Volvisti
- Year and Model: C30
in vtl's repo i see no p1? or where do you mean?
i am at the moment in germany at friends place, where we tried it at his car, anyone suggestions where i can buy here "good" pieces? (only staying until christmas though)
thanks
V
thanks
V
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
CANBUS sniffer question I'm on the hunt for a decent passive can sniffer. As I want to be able to intercept the packets & try too link them up the corresponding data when it's fetched from the eeprom memory data. It might end up in a dead end but its worth ago
- TonyToronto
https://github.com/cmolson/volvo-cem-cr ... s/one_passVolvisti wrote: 25 Nov 2023, 21:28 in vtl's repo i see no p1? or where do you mean?
thanks
V
https://github.com/cmolson/volvo-cem-cracker
I believe i got here.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Raspberrypi with a dual can shield + socketcan and cansniffer. Works for me and allows me to build python tools and prototype easily.oscilloscope wrote: 26 Nov 2023, 02:18 CANBUS sniffer question I'm on the hunt for a decent passive can sniffer. As I want to be able to intercept the packets & try too link them up the corresponding data when it's fetched from the eeprom memory data. It might end up in a dead end but its worth ago
It's then a matter of requesting the diagnostic parameters and correlating with the bytes from the streaming data with some slight offset to correct for delayed data between requested and actual.
oscilloscope
Did you have a diagnostic parameter list ? Or did you passively watch what was being fetched with dice when commonded ? , in the mean time I'll check the pi out and see what it's like to use. Is there a preference on the version of pi / dual canshield?dikidera wrote: 27 Nov 2023, 01:37Raspberrypi with a dual can shield + socketcan and cansniffer. Works for me and allows me to build python tools and prototype easily.oscilloscope wrote: 26 Nov 2023, 02:18 CANBUS sniffer question I'm on the hunt for a decent passive can sniffer. As I want to be able to intercept the packets & try too link them up the corresponding data when it's fetched from the eeprom memory data. It might end up in a dead end but its worth ago
dikidera
I in fact do have a parameter list. It's all contained in Volvo DHA and it's related dds files. Now, according to @vtl, the streaming CAN data's offsets are stored in VIDA as well, I really couldn't believe it. So in the end you might not even need to correlate data.
I personally had to, I had to reverse engineer the ECM and TCM to see params that were not mentioned in Volvo DHA.
oscilloscope
dikidera wrote: 29 Nov 2023, 01:05 I in fact do have a parameter list. It's all contained in Volvo DHA and it's related dds files. Now, according to @vtl, the streaming CAN data's offsets are stored in VIDA as well, I really couldn't believe it. So in the end you might not even need to correlate data.
Interesting... , the reason I'm trying too is to write a program to perform the synchronisation for the sid807evo and p2 cem unit. Codecard pulled the application for sale & the application is near impossible too crack unless you know how to reverse Oreans now called Themida. , I have tried and tried.. I had tried capturing the data with a logic analyzer. But that didn't capture anything of use. As I would need 144 pin analyzer which would probably cost a billion pounds. ( sarcasm)
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
You approach it wrong. https://xkcd.com/538/oscilloscope wrote: 29 Nov 2023, 06:48 Interesting... , the reason I'm trying too is to write a program to perform the synchronisation for the sid807evo and p2 cem unit. Codecard pulled the application for sale & the application is near impossible too crack unless you know how to reverse Oreans now called Themida. , I have tried and tried.. I had tried capturing the data with a logic analyzer. But that didn't capture anything of use. As I would need 144 pin analyzer which would probably cost a billion pounds. ( sarcasm)
oscilloscope
Your right! I'll get the wrench and head over too volvo R&Dvtl wrote: 29 Nov 2023, 07:00You approach it wrong. https://xkcd.com/538/oscilloscope wrote: 29 Nov 2023, 06:48 Interesting... , the reason I'm trying too is to write a program to perform the synchronisation for the sid807evo and p2 cem unit. Codecard pulled the application for sale & the application is near impossible too crack unless you know how to reverse Oreans now called Themida. , I have tried and tried.. I had tried capturing the data with a logic analyzer. But that didn't capture anything of use. As I would need 144 pin analyzer which would probably cost a billion pounds. ( sarcasm)
- 9858 Views
Last post by RickHaleParker
- 10187 Views
- 27 Replies
- 31330 Views
Last post by cn90
- 11974 Views
Last post by jonesg
- 6946 Views
