It’s made by T5Luke for config changes on P2 <MY04
Vida CEM swapping
Skavac
- Year and Model: 1998 Volvo S90
- Has thanked: 2 times
- Been thanked: 6 times
Quick question for everyone,
It seems there are 2 versions of P2 -04 CEM. One with PIN at 0x4000, the other with PIN at 0x6000. Are these interchangeable? Can I use a CEM with pin at 0x4000 to replace a CEM with 0x6000? Do I need to make any changes to the bin?
fmobile
- Year and Model: 2004 S60 restyle
- Has thanked: 1 time
Hi there!
I just would like to express respect to Vitaly and other guys for their efforts and the final elegant solution. I have cracked the PIN of CEM-L 31314468 successfully.
During cracking I noticed that some convenient features could be helpful, so I added:
1) 'Abort' button to exit from cracking process with ECUs exiting from programming mode, if brute-force is aborted by button the last checked value will be shown, so next time you can use this last value as initial value to continue brute-forcing.
2) Allows you to run brute-forcing starting any value, it can be useful if you are brute-forcing 4 bytes, which could take up to 18 hours, so you can break it in parts.
3) i2c LCD support, I see that Mark has committed LCD support with HD44780 chip, no cons about it. Just I had an i2c LCD only, and my implementation is done in accordance with the two points above.
All details can be found here https://github.com/feodorr/volvo-cem-cracker
Maybe it can be useful to someone.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Denso reverse engineering aside I decided to work on some Volvo instrument cluster reverse engineering.
My biggest hurdle is the memory map of a MC68HC912DG128 (ACPV) chip. I obtained some dumps, however they vary in size, some are 128KB others are 2 megabytes in size, I know the bigger one probably contains the translations/words. However these chips are not simple at all, they have many integrated memories inside the die, many modes of operation and different memory mapping based on those modes.
As such when I plug the binary into IDA, and select my chip, the layout is different probably because of the mode the chip was in when it was read, and whatever codes I could find seem to jump to incorrect memory offsets.
I was wondering if anyone had a hint on how to correct the layout of these chips so I can get accurate disassembly.
The goal is to figure out how the ECM or maybe CEM I am not sure, are reporting instantaneous/avg fuel consumption. My bifuel model because of it's configuration in the CEM cannot report this information which is honestly fairly valuable.
Specifically I want to see how and what changes this CAN configuration command affects in the instrument cluster
#send_can_message3([0x13, 0x01, 0x01, 0x01, 0x02, 0x02, 0x01, 0x04], arbid=0x01017FFC) #instant consumption, avg speed, fuel level
#send_can_message3([0x13, 0x01, 0x01, 0x01, 0x01, 0x02, 0x01, 0x03], arbid=0x01017FFC) #instant consumption, avg speed, fuel level 7th byte is instant fuel in 0x01
From there I will trace how the code updates the state and figure out which module is sending the information and in what format so I can implement it in my tool.
Now logically, the DIM is on the low speed bus, while ECM is on hi-speed which means the CEM is the one reporting fuel consumption, but the question still remains whether it's retranslating some ECM messages or is the CEM calculating fuel consumption based on fuel pump activation.
myname
- Year and Model: 2007 XC70
- Been thanked: 4 times
Does anyone know what to do if you get a dice unit that reads DICE-00000? I contacted the seller, and i got a partial refund on it already at least. anyway to fix it?
thanks
thanks
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
There's a DiCE firmware update tool. My DiCE is an early clone, it is actually a clone, not a fake pretend-to-be DiCE. It was not working in 64 bit Windows, so when time came for VIDA 2014D I had to update my DiCE. Apparently this method would not work for fake DiCE.
When my DiCE eventually dies, and I could not fix it, I'll get a JLR Mongoose, which has 2 CAN buses and works with VIDA. I have a single-bus Mongoose for Toyota, VIDA sees it out of the box and can make use of it, but of course it can't access the other CAN bus.
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
I am not sure this tool can help to restore firmware completely. I downloaded FW from similar working DiCE and updated DiCE with issue by programmer.vtl wrote: 24 Jan 2024, 04:49There's a DiCE firmware update tool. My DiCE is an early clone, it is actually a clone, not a fake pretend-to-be DiCE. It was not working in 64 bit Windows, so when time came for VIDA 2014D I had to update my DiCE. Apparently this method would not work for fake DiCE.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- 9326 Views
Last post by RickHaleParker
- 9299 Views
- 27 Replies
- 28790 Views
Last post by cn90
- 10796 Views
Last post by jonesg
- 5923 Views
