kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
MoVolvos wrote: 08 Sep 2024, 12:44 Did you do a write up or use another link somewhere for reference? If so can you provide that?
I followed this guide.
https://www.matthewsvolvosite.com/refur ... lvo-turbo/
The header paint was my idea. I also ran a tap through all the holes, and ran a die down all the bolts. That's an aftermarket WG actuator that I found on ebay. I opted to replace all the studs and nuts. I went aftermarket (FCP) for that because there's just no good reason to use that kryptonite alloy the originals were made of. I had to drill one out and it really sucked.
I don't recommend using a dishwasher for the parts clean step, both because heat plus water plus iron bad mmmkay, and because most wives aren't that forgiving. In fact, if I tried that, she'd do things that would be on the 6:00 news. I immersed the parts in gasoline, then wiped them down with acetone.
The only internal parts that got reused, were the turbine+shaft, and the compressor wheel.
5 others that came and went
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
It's been 5+ weeks since I was last out in Kära so today I visited a mate and then went for a drive to blow away the cobwebs. In a couple of weeks time she will be 19 years old and I have to say for an 'old burd' she can still put a smile on my face when the loud pedal is pressed, that 5 cylinder turbo engine is addictive.
I downloaded a GPS speedometer app to my phone to see how accurate the speedometer was and it seems to be 2mph slow at 50mph and around 3mph slow at 70mph and 'presumably' a little more inaccurate when 3 figures are achieved ;) which is all good to know with all the cameras that are watching our every move nowadays...
Once home I vacuumed the interior and she was put back into her bed
11 Septs.jpg (315.26 KiB) Viewed 613 times
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
hiroku
Year and Model: 2002 V70 T5
Has thanked: 21 times
Been thanked: 9 times
Post by hiroku »
The speedo on my 2001 reads about 10% faster than the actual GPS-measured speed. It's weird because AFAIR the wheels and tires currently on the car are the factory original ones according to VIDA.
I guess that makes the car seem faster, which is a good thing?
kcodyjr
Post by kcodyjr »
Finished reinstalling my hand-rebuilt turbo, all four coolant and oil lines, crank down on the turbo-to-manifold nuts, and ready to install the new cheap aftermarket downpipe.
Of course, this was an epic display of contortionism and profanity, considering I was replacing the coolant hoses and didn't remove the angle gear. Getting the lower supply line back on and clamped would have netted a small fortune if I kept a swear jar, which is exactly why I don't.
Catback and intake piping boostability kit still pending from IPD. It'll be on the blocks awhile longer.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Cleaned the throttle body on the 06 S60 R. It threw a throttle body code and ran poorly back in May, finally had the car here to work on it. I can't tell if it runs better now but the TB was pretty dirty, I cleaned it up quite a bit. Don't think it had ever been done. At least it won't likely throw another code on my daughter.
As a guide I used this excellent post from Swedespeed: https://www.swedespeed.com/threads/how- ... ng.550426/. Replaced the gasket with a Volvo branded one, raised side up. The electrical connector to the TB was very difficult to remove but otherwise this was a super straightforward job, about 4 hours in total working slowly and cleaning up the engine bay as I went.
Also the car came in with a burnt out daytime running light (9006 bulb). Turned out the connector socket was fried in the + end. I had to replace the socket with a generic one from O'Reilly's.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
erikv11 wrote: 16 Sep 2024, 21:29 Also the car came in with a burnt out daytime running light (9006 bulb). Turned out the connector socket was fried in the + end. I had to replace the socket with a generic one from O'Reilly's.
I picked up some ceramic sockets a while ago off ebay... been putting off installing them for 2 years mine are all mangled and half are just the female spade connectors left no plastic...
04s60 2.4
04xc70 2.5t
Post by erikv11 »
br0dy519 wrote: 17 Sep 2024, 10:14
I actually did use ceramic from the FLAPS. :D
I was wondering if I could just replace the bulb and safely use the burnt/mangled connector for now, that's good to know. Decided I probably better fix it since this is currently my daughter's car and she lives six hours away.
br0dy519
Post by br0dy519 »
My ceramic sockets have pigtail wire ends. Consensus is it necessary to solder/heatshrink these connections or would a simple crimp butt connector work ?
04s60 2.4
04xc70 2.5t
kcodyjr
Post by kcodyjr »
br0dy519 wrote: 17 Sep 2024, 12:24 My ceramic sockets have pigtail wire ends. Consensus is it necessary to solder/heatshrink these connections or would a simple crimp butt connector work ?
If you don't want to solder and heatshrink itself, use "Heat Shrink Solder Sleeve Butt Connectors" (just search Amazon for that). It does it all in one step with a cigarette lighter.
I'd be concerned about moisture getting into it, PLUS the fact that I just don't like crimp connectors.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
kcodyjr wrote: 17 Sep 2024, 13:00
Yea this is what I used for my ceramic pigtails. The heatshrink solder connectors are so easy to use. No crimping needed. Just heat.
