I'm hoping to program a remote key on 2004 XC90 using PIN and IM608. I know generate key from dump will work for transponder, but I would like remote programming to work if possible. I'm not sure how to message you directly. Here are the dumps with inversion and without.charlie13 wrote: 09 Apr 2022, 11:55Read Intel 28F400 memory and send me I can give you the pin you read. You will do path and when the pin input function is added, as in the other modules, you will enter your own pin. This will allow you to embed car conf. I/0 software and using cem changes.
In fact, when you read the desoldered flash, you will also save the changes you want to make
Vida CEM swapping
- 2004 VOLVO XC90.rar
- (209.86 KiB) Downloaded 61 times
Dudde
- Year and Model: 2005 V70 and more
- Has thanked: 17 times
- Been thanked: 17 times
Read UEM with im608 and program remoteI'm hoping to program a remote key on 2004 XC90 using PIN and IM608. I know generate key from dump will work for transponder, but I would like remote programming to work if possible. I'm not sure how to message you directly. Here are the dumps with inversion and without.
IM608 prompts me to to get CEM info when Remote programming?Dudde wrote: 17 Dec 2024, 12:09Read UEM with im608 and program remoteI'm hoping to program a remote key on 2004 XC90 using PIN and IM608. I know generate key from dump will work for transponder, but I would like remote programming to work if possible. I'm not sure how to message you directly. Here are the dumps with inversion and without.
Hello,
first time poster here on MVS. Just discovered this thread a few days ago and read through the first 50 pages or so... Thank you all for the amazing work reverse engineering and hacking into Volvo.
I would like to clone the CEM in my 2006 XC90 to another unit I am planning to pick up from the junkyard. Is this possible now?
Also I would like to crack the PIN for my 2002 S60. Is there support for the early P2s already?
I will continue reading the thread but its 300+ pages already so there is still much to catch up and I really need to get back to working my day job lol. I havent been able to figure out the answers for the above questions yet hence the reply.
Thank you in advance!
scaro
- Year and Model: Volvo&Audi
- Has thanked: 14 times
2002 S60 you have to read bdm first (as of now) (knowing soldering or "pogopins")There is info from helpful and nice ppl in thread how to.
2006 Cem you can clone but maybee not without buying some tools and/or be a bit handy on soldering. Info in thread to.
For example to make full clone, TTL to read and write MCU and something to read 93LC86.
Think this is the "cheapest" way about this time without being good at programming?
244 Turbo (86K miles) 1983
242 B230FK, Rollcage, LSD 1984
244 B21A with R-Sport Turbo-kit 1980
A5 2.0TFSI Quattro Conv. 2012
A4 1.9TDI 1997 BV43, 11mm vp37, 0.26 nozzels, 6speed, A8 brakes front, S4 discs/calibers rear
A4 1.9TDI 1998 Daily
Treur
- Year and Model: 2007 V70
- Has thanked: 3 times
- Been thanked: 7 times
For cloning you must remove cem from car, and transfer data from MCU and eprom to other cem. I use China xprog for MCU and tl866+ for EPROM.haifisch wrote: 18 Dec 2024, 04:21 Hello,
Treur
Does anyone know how the odometer is generated in DIM?
I tried the formula from the ETL calculator, but it gives an accuracy of ~250 km
- 9286 Views
Last post by RickHaleParker
- 9240 Views
- 27 Replies
- 28624 Views
Last post by cn90
- 10720 Views
Last post by jonesg
- 5857 Views
