What non automotive projects and repairs are you doing?
Forum rules
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Re: What non automotive projects and repairs are you doing?
Nothing runs like a Deere.
- Been thanked: 1000 times
My farming family always had Farmalls and later CaseIH tractors. This is the first John Deere I have worked on. It was, as always, purchased because it was available at the right price.
- BlackBart
There's a guy here with a weedy rural lot at a major intersection of arterials, with three antique FORD tractors for sale. Beautifully painted. They've been for sale for 10 or 15 years. The paint is starting to fade.
I spoke too soon. The JD mower cranked today for about 5 seconds then would do nothing at all or just buss sometimes. I assume I still have poor wires somewhere in the starting circuit.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
The Homelite HydroSurge pressure washer hose repair failed; the 25' hose has deteriorated at many places. It appears Homelite/Ryobi have something in common. I'm looking at Ryobi replacement hoses and pressure washer gun from Home Depot to refurbish the unit.
Will it be an over kill to spray paint over the red color of the Homelite unit to Ryobi green - just the frame, not pump/motor? Alternatively, peel-off Homelite label/sticker at minimum after the refurbish.
Yesterday, I found the battery ground cable was not as good as I thought. It would check OK with the Ohm meter, but would not carry a high current. A new cable will be purchased.
I think both Homelite and Ryobi have both been made in China the last several years. Paint it any color you want. I also think any pressure washer hose would interchange.
Big day for the JD Mower. New battery cable allows perfect cranking. Checked and have good spark. It will run a few seconds on carb cleaner, but is not yet getting fuel pumped to the carb. One rear tire has a new tube and now holds air.
New bamboo sprouts are growing fast!
Alternate plan is the push mower, but I know how hard that is.
Yesterday, I checked out the fuel pump on the Kohler engine. It is a cam driven mechanical fuel pump. I took it apart expecting to find a torn diaphragm, but it all looked good so I put it back together. I tried sticking the inlet in a cup of gas and pumped the handle by hand. It took many pumps but then the fuel shot out the outlet. It all seemed OK it just needed priming. Then I made a new gasket for attachment to the side of the block.
Today I reprimed the fuel pump and fastened the fuel pump with gasket to the block. I set up a short hose into a fuel tank and tried to start the engine. A bit of cranking and choke/ throttle adjusting and it was running steady!
Then I fought the 8 inch front tire off the rim and found it had an old tube inside. The tire was rusted to the rim and did not want to come off. Tire irons and hammer won the battle. I have a home made tire bead breaker that got things started. The new tube was installed and the tire inflated to seat the bead.
Getting close to using the big mower.
I got out the push mower to mow between some trees where I will not be able to use the John Deere. I started easy and ran OK.
