yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Up in Toronto the lane orders were shifted by the powers that be. Instead of | fast | medium | Slow | it has now become | medium | slow | fast |.
We have classics up here like Honda Civics driving with high beams on and large suv's going way to slow in the fast lane.
2008 S60 2.5T Auto (Sold)
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Was checking my fuses and relays and figured I'd investigate why I don't have an airpump relay. I also don't seem to have an air pump based on the diagrams I've looked at. I started a thread about it but I'm wondering if it means it was deleted, or never had one..
07 V50 T5 AWD M66 ~146k miles
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
smacknab wrote: 20 Aug 2020, 08:28 Was checking my fuses and relays and figured I'd investigate why I don't have an airpump relay. I also don't seem to have an air pump based on the diagrams I've looked at. I started a thread about it but I'm wondering if it means it was deleted, or never had one..
'99+ P80s never had air pumps. The relay is still shown on the fuse box, but it was never there from the factory. VVT took place of the air pump on RN engines.
Has thanked: 1505 times
Been thanked: 3817 times
bmdubya1198 wrote: 20 Aug 2020, 09:09
Unless you are special....
bmdubya1198
I'm gonna need proof of the pump being there...
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
That's why the average P80 is fun, great Q-ships, just cruise (fast) and draw no attention as long as you are smooth and aware.
Current Volvos:
Waiting on parts for Earl the 1998, I tried to harvest the power steering lines and brake lines from Clarke the 1998
The PSlines beat me at the rack on the rear, the brake lines at the rear union
Both will come when I harvest the rear and rack on scrapping
No good deed goes unpunished
yanga001
Post by yanga001 »
added roof rails from an 850, repaired a trunk latch that would not engage.
smacknab
Post by smacknab »
Car wouldn't start today but I tried a bunch of thing but I ended up starting it by jiggling the key a bunch of times.
Crank no start, sometimes it would fire a couple of times then just a whirring sounds from what I assume was the starter. Checked the battery connections because my negative teminal bolt is a replacement that's not square and spins a little. Voltage at the battery 12.5. I didn't have a tire pressure gauge but I used the cap to check the fuel rail and got a spurt of gas out of it. I've been having immobilizer issues so I swapped out the junkyard unit with my old one. Pushed the MAF and throttle body wire connections in to make sure they were in. Tightened my crank position sensor (above the flywheel, if that the right name?) in, and checked that connector. Fuel line connector next to exhaust manifold tight. All my evap lines are good.
Once it ran I unplugged the MAF while idling and noticed no change in how it ran.
I had ordered a new throttle body and MAF earlier this week for other issues, so we'll see if that addresses anything.
bmdubya1198
Hmm, I wonder if your ignition switch is going out too.
