Wondering what to do? 1998 S70 blown head gasket Topic is solved
maujsur
Year and Model: Volvo 2018
Post by maujsur »
Take a chance on an old bone yard engine. Think the go for maybe $400+tax (approx price). You can buy bone yard insurance but you only have like 30days to find a good used one. I would by an engine put it on a stand and rebuild the new motor. Some work yes but very rewarding in the end!
rnelson1044
Year and Model: S70 GLT, 1998
Has thanked: 2 times
Been thanked: 5 times
Post by rnelson1044 »
Uodate: After completing head renewal and replacing head gasket, car ran beautifully for week or so. Then, suddenly will not start. Have spark, plugs are wet with fuel, air pump running fine. Compression feels fine when turning crank pulley. Fuel pump running fine (confirmed by placing jumper on fuel pump relay socket). Replaced cam position sensor (male plug from sensor had self-destructed). Have ordered new fuel pump relay.
Any other thoughts?
rnelson1044
Replaced fuel pump relay; still no start. Will check fuel pressure at schrader valve wtih fuel pressure gauge.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Test the compression of each cylinder while cranking.
It may have slipped timing. Check the timing marks on belt.
Check all electrical connectors - something may be loose.
