98 v70: fail to start when cold
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 327 times
Been thanked: 87 times
Re: 98 v70: fail to start when cold
Post by CIK7 »
So another update. It cranks and starts most times unless it sits for a while in the cold. So last night I tried to start it 5 times and it cranked for about 1 second or less (literally, not figuratively) each time and cut off. Battery charger showed 12.6v and 96% last night before attempting to start again immediately. It started up no issue. Anytime I hook up the charger (wall outlet power only, its not a battery bank), I can start it immediately. Would this be a starter issue?
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Can you connect a voltmeter to the starter to watch voltage while you try to start? Do this without the battery charger connected.
CIK7
Post by CIK7 »
volvolugnut wrote: 31 Oct 2023, 11:28 Can you connect a voltmeter to the starter to watch voltage while you try to start? Do this without the battery charger connected.
Not sure when Ill do this. Will be a few days. Got tomorrow and thurs, then friday morn to get through. Hopefully getting a good complete dashboard from LKQ in Tulsa on Thursday.
