Fix or Scrap? Topic is solved
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Re: Fix or Scrap?
Post by foggydogg »
The brackets and bits unique to the AWD cars are prone to rust for some reason, like the rear brake backing plates and the center bearing support plate ( ask how I know.) Rear calipers are hard to come by too.
Plus one for saving the rack and the bolt on stuff off the engine. Blower motor and all the relays everywhere, and all the blend door actuator motors. Driveshaft, including the coupler on the rear diff, bur the entire rear end is right stout and would take up lots of space; the rears seem to rarely fail under normal circumstances. Both front axles, shocks and struts if the car can be made immobile.
Fuel pumps if they can be had without dropping the tank, a process that keeps some of our little therapy group awake at night; I don't remember if one of the pumps can be had through the access plate under the cargo floor.
Glad both parties could get together on this deal, well done.
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Try to get EVERYTHING off Yertrude that you can somehow store. Take the time to remove everything carefully, and save all these rare and low mileage AWD parts.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
TRNorton
Year and Model: 99 V70 XC
Has thanked: 48 times
Been thanked: 12 times
Post by TRNorton »
I'm thinking I should also swap the radiator out since Yetrude had less than half the miles as Frankentrude.
Should I do the heater core as well ?
99 V70 XC Silver 95K "Yetrude" - Totaled by a Semi - Vital parts harvested
99 V70 XC Polar White 200+K "Yeti Frankentrude" - Blown Engine Resurrected w/ Vital Organ Transplant from sister "Yetrude"
"Be Curious...Not Judgmental" - Ted Lasso
Has thanked: 1502 times
Been thanked: 3817 times
Not really a hard enough job to justify proactive replacement , IMHO
Has thanked: 1842 times
Been thanked: 1710 times
As all the fluids have to be removed, with the coolant out you might as well. Having said that, both heater cores are 25 years old, maybe fitting a reasonably priced aftermarket one is the way to go. Again, check both radiators carefully for damage and splitting at the seams. If the other car has had a broken crank mount it could cause problems with the upper radiator pipe outlet or end plastic to aluminum.
TRNorton
Post by TRNorton »
Service records on Frankentrude show the heater core is showing signs of leaking and advice it be replaced. Looks like a new one is not very pricey so I will go ahead and have a new one put in considering the labor of removing Yetrudes.
foggydogg
Post by foggydogg »
TRNorton wrote: 18 Jun 2024, 04:34 Service records on Frankentrude show the heater core is showing signs of leaking and advice it be replaced. Looks like a new one is not very pricey so I will go ahead and have a new one put in considering the labor of removing Yetrudes.
Good instinct on a new part there; stick with either Blue Box Volvo if you can find one at a decent price, or a known brand name - Nissens or the like.
https://www.fcpeuro.com/products/volvo- ... -s70-v70-1
Years ago I found one made by Behr for my first 850.
ipd shows one made by "MTC", but there isn't any way to know who that is exactly. Swedish Cars Parts in Chicago sells one that Robert likes.
https://www.swedishcarparts.com/parts/s ... xt=9144221
As usual, avoid anything URO.
TRNorton
Post by TRNorton »
The date for Surgery is set !!
My mechanic at Vol-Tec in Portland will be receiving both patients on Monday and the swap begins on Tuesday!!
I will have the engine & tires swapped and the heater core replaced at my mechanics - then have the husk of Yetrude towed to my home where I will commence to harvest the rest of her vitals. I will swap the seats and such. I promise to post photos of the progress!
Unfortunately I have to leave town for work and won't be able to see or work on them until mid July, but what a delightful project to return home for!
Yahoo!!
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
This project will be like eating an elephant - one bite at a time.
